Duet 3 questions
@nightmare90gt said in Duet 3 questions:
@dc42 said in Duet 3 questions:
If I do the calculations for the nema 34 the max voltage is 45
Do you mean that is the voltage you need at the highest speed you want to run the motors? Or something else?
The max voltage the motor should be driven from my understanding.
There are two voltages commonly specified for stepper motors:
- The phase voltage is the resistive voltage drop at the rated current. It should be much less than the VIN voltage, but is otherwise irrelevant when using constant current drivers (which Duets and all other modern control electronics use).
- The insulation rating. This is usually many tens of volts, and should be higher than the VIN voltage used.
https://www.geckodrive.com/support/step-motor-basics/power-supply-basics.html
This is how I found the max voltage for the motor sounds like the insulation rating your referring to above.
The formula they give:
32 * √L = VMAX
is specific to the Geckodrive, and does not translate directly to other drivers. What it suggests to me is that the Geckodrive has a minimum quantum of time by which it can adjust the on-time, and that time quantum is quite long.
It's true that very low inductance motors and high supply voltage could be problematic, but to be a problem for the Duet 3 drivers I think the inductance would need to be well under 1mH even with 30V supply.
Ah ok makes sense thank you for clearing that up for me.
So are you saying that because the motors in question have a inductance of 2mH I wouldn't be able to use the Duet 3?
Yes, no problem.
Yes, no problem.
I'm guessing you read it as would and not would not. If so I am looking forward to seeing the progress with this board as I will be using to control my cnc.
Yes, you can 2mH high current motors with Duet 3.
FWIW the motors I test Duet 3 firmware with are these https://www.omc-stepperonline.com/nema-34-cnc-motore-passo-passo-4-5nm-637oz-in-5-5a-86x86x80mm-key-way-shaft.html?search=34HS31-5504S. But I chose those when the rated current for Duet 3 was lower than it is now.
I am looking at this motor for a better pair to the duet board (less amp rating)
Also maybe you can help me understand the inductance number. Would it be better to have that number bigger or smaller?
please read the guide
https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Inductance
