    Stepper motor Inductance: 5.4mH ?
    929
    • CJ.BRAVOundefined
      CJ.BRAVO @Veti
      @Veti
      ok.
      So to make things clearer for me, I should separate between the rated current of the drivers (2.4A) and the total amp that the duet can take?
      I understood that I do the whole calculation thing ( ( 3.2/24 ) * 2.8A = 0.37A ) to figure out the total current I can put on the board - in this case I can use a few 2.8A motors on the duet with no worry but I should take notice if exceed the rater current for driver. right?
      • Vetiundefined
        Veti @CJ.BRAVO
        @CJ-BRAVO said in Stepper motor Inductance: 5.4mH ?:
        the drivers will shut down if they get to hot and you can not set the current higher than allowed.
        do take notice of the fuse
        7.5A for the VIN going to the heaters and stepper motors
        • wilrikerundefined
          wilriker @DocTrucker
          @DocTrucker said in Stepper motor Inductance: 5.4mH ?:
          ...but shouldn't the thermal protections should kick in to stop you killing the drivers?
          Yes, they will. But depending on how determined you are to fry your board you could probably still accomplish it - but that requires pure will to do so.
          @CJ-BRAVO When it comes to stepper drivers (the ones used on Duet boards that are current chopping) you can ignore any voltage in the system. They will only care for current. On Duet 2 you have a firmware limit of 2.4A - if you set it to 154A it will still not exceed 2.4A.
          @Veti The type of this fuse will only blow if it is a multiple of the rated current (2-10x depending on the actual fuse used) and only is there for a short-circuit protection. You can run all steppers at 2.4A without blowing the fuse.
          Manuel
          My Tool Collection
          DocTruckerundefined CJ.BRAVOundefined 2 Replies Last reply Reply Quote 0
          • DocTruckerundefined
            DocTrucker @wilriker
            @wilriker he he, fair enough! 😄
            ...in part checking for my own 'procedures'!
            • CJ.BRAVOundefined
              CJ.BRAVO @wilriker
              @wilriker said in Stepper motor Inductance: 5.4mH ?:
              hey, thanks for the answers.. still what to verify -
              "You can run all steppers at 2.4A without blowing the fuse." : because the whole "motor voltage" (3.2v) divided by the power supply (24v) times the rated current (2.8A) comes down to "not really" 2.8A ?
              wilrikerundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • wilrikerundefined
                wilriker @CJ.BRAVO
                @CJ-BRAVO again, forget about the voltage when it comes to stepper drivers. It's only the current that matters - the same for the fuse.
                In theory 5*2.4A (=12A) is larger than the 7.5A fuse but since this fuse will not blow below 15-20A continuous current draw it won't be a problem.
                Voltage only matters for top speed without losing torque.
                EDIT: sorry for all this nonsense. I was replying to about 3-5 totally different questions in my head. 🤦
                Manuel
                My Tool Collection
                CJ.BRAVOundefined 1 Reply Last reply Reply Quote 0
                  dc42 administrators @CJ.BRAVO
                  Correct. At low motor speeds, using 2.8A peak current, the power required per motor will be 2.8 * 3.2 watts, times 5 motors makes 49W. If the stepper drivers were 100% efficient, the current drawn from the 24V supply would be 49/24 amps which is just over 2A.
                  In practice the drivers are not 100% efficient, so the current draw will be a little higher. The current draw will also be higher when accelerating, but acceleration doesn't last long.
                  • CJ.BRAVOundefined
                    CJ.BRAVO @wilriker
                    @wilriker
                    🙂 so which part of what you said should I ignore ?
                    thanks!
                    • wilrikerundefined
                      wilriker @CJ.BRAVO
                      @wilriker
                      Everything I said regarding input to the drivers.
                      Manuel
                      My Tool Collection
                      • CJ.BRAVOundefined
                        CJ.BRAVO @wilriker
                        @wilriker
                        so just make sure not to exceed 2.4a per driver and regarding duet board is fine cause its actually not drawing that much for the drivers. or something like that.
                        • wilrikerundefined
                          wilriker @CJ.BRAVO
                          @CJ-BRAVO Unless you recompile the firmware with the limit increased you cannot exceed 2.4A/driver output current anyway. All you have to do is to match your steppers to perform well up until this limit (or even below). Also you need to actively cool your board when going beyond 2A/driver.
                          To get to problems on the input side you will probably have a hard time finding steppers that would get you there (i.e. steppers that have a rated voltage at or above your PSU voltage). And even if you manage to find those they would have to be moved at a crawl-speed or lose torque basically immediately. Short: there is nothing to worry on input side.
                          Manuel
                          My Tool Collection
                          • CJ.BRAVOundefined
                            CJ.BRAVO @wilriker
                            @wilriker
                            cool thanks
