    Leadshine hybrid servo drive tuning
    • Depundefined
      Dep
      Continuing the topic: https://forum.duet3d.com/topic/12582/mesh-calibration-not-working-or-what-am-i-doing-wrong
      Briefly - the problem with the first layer.
      I think now the main problem is skipping Z steps
      On the Z axis I have a Leadshine hybrid servo drive HBS507
      And all that tested before that was with the setup of the M569 P7
      After the last print, I noticed Hiccups 64
      Next, I made the M569 P7 T2.5: 2.5: 5 - no result
      Then M569 P7 T5: 5: 6 and Hiccups 20, and got better print
      Then M569 P7 T20 and even better print and Hiccups 4
      True, I constantly executed the M122 command during the printing process - it seems that it resets Hiccups
      Where to go next? What should be the timings for my motor?
      • Depundefined
        Dep
        I just think 20ms is too much.
        Can you share what settings you think are normal or use yourself?
