    Problems with BLTouch V3.1
    711
    • btmerzundefined
      btmerz
      I have a Duet 2 Wifi Bord running firmware version V2.04RC4. Attached to that board there was a BLTouch V1.0, which worked perfectly.
      Due to a mechanical defect on this sensor, I had to replace it.
      Now I have a BLTouch V3.1 Sensor, but it doesn’t work correctly any more. On power on, the sensor makes the self-test and I am able to deploy and retract the probe correctly.
      But when I try to home, the pin touches the bed , but the board doesn’t recognise it. So that the nozzle crashes into the bed. There appears no blue light…
      What do I have to change to get this V3.1 sensor to run?
      Here is my setup:
      config.g:
      M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P600 X49 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X50:450 Y50:450 S200 ; define mesh grid
      deployprobe.g:
      M280 P7 S10 I1; deploy BLTouch
      G4 P100 ; Pause 100ms
      M280 P7 S60 I1; Touch SW Mode
      retractprobe.g:
      M280 P7 S90 I1; retract BLTouch
      homez.g:
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 H2 X210 Y250 F6000 ; go to first probe point
      G1 H2 Z5 F100 ; lift Z relative to current position
      Thank you for your help.
      • fcwiltundefined
        fcwilt
        Just FYI you can always safely test this sort of thing by, in this case, moving the nozzle well away from the bed, triggering the test and using your finger to lift the pin. This way you have time to shut things down rather than have a bed crash.
        In any case you need two files: deployprobe.g and retractprobe.g and they each should only have one M280 command that performs the associated action.
        Unless something has changed "Touch SW Mode" is not used. At least my BLTouch 3.0 works fine without it.
        • btmerzundefined
          btmerz
          Hi fcwilt. thanks for your reply. After I had the first crash, I of course tested it the save way. Can you post your config and probe files?
          I also tested it without the Touch SW Mode - same negative result.
          Becomes your sensor blue if it triggers? Mine is only red...
          jaurandundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
          • Vetiundefined
            Veti
            tripple check the wiring.
            • jaurandundefined
              jaurand @btmerz
              @btmerz My sensor is blue when the pin is down and solid red when the pin retracts. It does blink red when the pin is up and the alarm mode is triggered.
              • btmerzundefined
                btmerz
                So then it could be, that I have a defective sensor? When I deploy the probe with M401 it is dark (red switches off, no blue).
                • Vetiundefined
                  Veti @btmerz
                  @btmerz said in Problems with BLTouch V3.1:
                  do you use M501 and config-overwrite.g?
                  • btmerzundefined
                    btmerz
                    No,
                    sorry, but what's that for?
                    Doest it read the whole config at power on?
                    What should be inside the config-overwrite.g file?
                    • Vetiundefined
                      Veti
                      it could overwrite your settings. please post the entire config.g
                      • fcwiltundefined
                        fcwilt @btmerz
                        So you created the two files I mentioned and entered in the correct M280 commands?
                        Did you verify operation using M401 and M402?
                        delvisundefined 1 Reply Last reply Reply Quote 0
                        • delvisundefined
                          delvis @fcwilt
                          @fcwilt yes. M401 and M402 are working as expected. Deploying and retracting the pin.
                          • fcwiltundefined
                            fcwilt @delvis
                            @delvis said in Problems with BLTouch V3.1:
                            Well then it should work in all instances that rely on M401 and M402.
                            Try changing the P parameter in the G31 command to 20.
                            SInce M401 and M402 work we know that the wiring that controls the BLTouch is working.
                            What we don't know yet is if the wiring which sends the signal to the Duet is working. If something is wrong there that could explain the problem you are seeing.
                            Double check that wiring.
                              Phaedrux Moderator @fcwilt
                              Check the white wire especially. I believe that is the signal wire.
                                It sounds as though either the BLTouch isn't triggering, or there is a short circuit between the signal output and ground, or the internal pullup resistor in the Duet MCU isn't working. Suggestions:
                                1. Send M558 without parameters and check that it reports probe type 9.
                                2. Disconnect the white wire from BLTouch to the Duet (and the black wire at the same time if it's easiest, it doesn't matter). The Z probe reading in DWC should jump to 1000. If it does, that implies that the BLTouch isn't triggering, or that its output has a large leakage current, or there is a stray strand of wire shorting the white and black wires together.
