Duet3D 3 CNC support
    orc
    I'm a total newbie in the CNC world and also quite afraid about currents, especially because I have burnt a driver before.
    This is my CNC machine's stepper spec:
    ![https://i.imgur.com/yZ05XVj.png](image url)
    The Duet3D 3 specs say:
    "6 Next Generation Trinamic 5160 stepper drivers running at up to 4.45A RMS, 6.3A peak with firmware control of the full feature set including up to 256 microstepping, StallGuard 2 and StealthChop2"
    But I'm not sure if I should multiply the current by each phase or not.
    Do you think this board handle these motors?
      The rated current we quote is per phase, so Duet 3 will easily handle those motors. Duet Wifi and Duet Ethernet can handle them too, but if using one of those then you would need to cool the board with a fan.
        orc
        Okay. No I'm even more confused.
        Does this board has WiFi? Will it have a WiFi enabled version?
        What do you mean by "The Ethernet port provides the ability to directly network to the board - along with the built in SD card this provides a reduced feature set"
        A reduced feature set? What features can't I use?
        undefined 1 Reply Last reply 27 Nov 2019, 09:38 Reply Quote 0
          deckingman @orc
          @orc Give us a clue. Which board are you looking at? The Duet3 or the Duet 2 WiFi or the Duet 2 Ethernet or the Duet Maestro?
            We intend the Duet 3 to be used with an attached Raspberry Pi 3B or 4 or other single board computer (SBC). The SBC provides the network connectivity, and these models of Raspberry Pi provide both Ethernet and WiFi.
            However, the Duet 3 can also be used in standalone mode (without a SBC). In that configuration, the network connection is via the built-in Ethernet interface.
              PS - I have updated the comparison chart at https://duet3d.dozuki.com/Wiki/The_Duet_family_of_motion_control_electronics to include Duet 3.
              4 out of 6
