    Strange X and Y homing (axis that shouldn't move, move)
    • MJCTundefined
      MJCT
      Hi, having a problem with the X and Y homing.
      First the code:
      ; generated by RepRapFirmware Configuration Tool v2.1.3 on Thu Nov 28 2019 16:04:13 GMT+0000 (Hora padrão da Europa Ocidental)
      M550 P"AA 300x300x600" ; set printer name
      M667 S1 ; select CoreXY mode
      M551 P"AA" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z4000.00 E92.60 ; set steps per mm
      M906 X1750 Y1750 Z1750 E1750 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y15 Z0 S1 ; set axis minima
      M208 X290 Y295 Z585 S0 ; set axis maxima
      M574 X1 Y1 S0 ; set active low and disabled endstops
      M307 H4 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
      M558 P9 H0.5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X25 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X20:270 Y20:275 S20 ; define mesh grid
      M143 H0 S110 ; set temperature limit for heater 0 to 110C
      M563 P0 S"Extr 1" D0 H1 F0 ; define tool 0
      T0 ; select first tool
      Problem, when X axis is going back a few mm, the Y axis also moves slightly in the positive direction and it shouldn’t, there is nothing in the code telling y axis to move!
      Homing the Y axis is even weirder. It homes the first time but it doesn’t move back for a second passage, besides that, when it hits the Y endstop the X axis moves a little bit to the positive direction.
      But when I use the dashboard to move the axis they move as expected, only in the reight direction and only the specified axis.
      ; homex.g
      ; called to home the X axis
      G91 ; relative positioning
      G1 H2 Z0.5 F6000 ; lift Z relative to current position
      G1 H1 X-295 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000 ; go back a few mm
      G1 H1 X-295 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-0.5 F6000 ; lower Z again
      G90 ; absolute positioning
      ; homey.g
      ; called to home the Y axis
      G1 H1 Y-315 F1800 ; move quickly to Y axis endstop and stop there (first pass)
      G1 H2 Y5 F6000 ; go back a few mm
      G1 H1 Y-315 F360 ; move slowly to Y axis endstop once more (second pass)
      Thanks
      • Vetiundefined
        Veti
        @MJCT said in Strange X and Y homing (axis that shouldn't move, move):
        the H2 option is not compatible with corexy. delete the h2 part
          H2 is fine for the Z axis, but for the X and Y axis it's telling it to turn a single motor, which results in diagonal movement on coreXY.
          You don't need H2 on those X and Y moves anyway since it's been homed once already. The movement to backoff the endstop can be done as normal.
          • Vetiundefined
            Veti
            the configurator generates this at the moment. so this should be changed. @chrishamm
            • MJCTundefined
              MJCT
              Thanks for the help.
              The strange movements in the X and Y stopped and the Y axis goes for a second pass like it should be.
              ; homex.g
              G1 X5 F6000 ; go back a few mm
              ; homey.g
              G1 Y5 F6000 ; go back a few mm
