    Maxiwatt circle heater
    543
      dc42 administrators @matej1006
      No, the temperature sensor in that heater is a thermistor, not a PT100.
      • Dougal1957undefined
        Dougal1957 @dc42
        @dc42 said in Maxiwatt circle heater:
        They will also do one with a PT100 (I've just ordered one).
        matej1006undefined 2 Replies Last reply Reply Quote 0
        • Vetiundefined
          Veti
          for pt100 you will need this
          https://www.duet3d.com/PT100_DaughterBoard
          • matej1006undefined
            matej1006
            what is better pt100 or thermistor
            i will order soon but i need to order 4 because i building toolchanger.
              matej1006 @Dougal1957
              @Dougal1957 how much is with pt100
              with thermistor is 11usd plus 15 shipping to slovenia
                Dougal1957 @matej1006
                @matej1006 said in Maxiwatt circle heater:
                they charged me same price. but you have to ask them directly and they will pro forma invoice you strange thing is that shipping was more (but they do say on the website that international shipping will be amended) and the other thing is that it was done from there office in spain so I paid eu VAT at the time as well so shouldn't get stung for import taxes but we will see. If you are getting 4 the shipping will be split between them I guess.
                • Vetiundefined
                  Veti @matej1006
                  lots of article on the web about that.
                  https://blog.wika.com/knowhow/pt100-pt1000-or-ntc-which-is-the-right-measuring-element/
                    Also https://duet3d.dozuki.com/Wiki/Temperature_sensors.
                      deckingman
                      I used to have a PT100 (4 wire) on my bed but it was always "noisy". The result of that "noise (about +_ 1 degree) the bed temperature would always be controlled at about 1.5 degrees higher than the set temperature. Changing it to an E3D cartridge thermistor cured the noise problem and bought the controlled temperature down to the set temperature. Having said that, on my Duet 3 with the same cartridge thermistor but slightly different cable routing, I had a noisy signal again. In the end I cured that by using screened cable. My take on it is that using a more accurate sensor is only valid if the signal condition is noise free.
                        matej1006
                        This post is deleted!
                          @Dougal1957 and is better then thermistor
