Firmware 2 to 3 with BLTouch Help.
Hay all,
I thought i would give firmware 3 a go on my Duet WIFI (1.02)
and with the naming of things i just wanted to see if i have got it write.
Before i take the plunge, my main problem is the BLTouch
Using BLTouch Guide
https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/Firmware 2
Config.g
; generated by RepRapFirmware Configuration Tool v2.0.4 on Tue Sep 24 2019 20:19:18 GMT+0100 (British Summer Time); General preferences
M550 P"Tronxy X5s" ; set printer nameM667 S1 ; select CoreXY mode
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S0 ; Physical drive 4 goes backwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E429.18 ; set steps per mm
M566 X600.00 Y600.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z1500.00 E18000.00 ; set maximum speeds (mm/min)
M201 X3000 Y3000 Z1000 E10000.00 ; set accelerations (mm/s^2)
M906 X1100 Y1100 Z1100 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X-17:310 Y-27:310 Z0:300 ; set axis minima/Maximium; Endstops
M574 X0 Y0 S0 ; set active high endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H10 F1000 T8000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P500 X37 Y-3 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X5:305 Y5:305 S20 ; Define mesh grid; Heaters
M305 P0 T100000 B3950 R4700 ; set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4725 R4700 C7.06e-8 ; set thermistor + ADC parameters for heater 1
M143 H1 S290 ; set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S255 I0 F1000 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings
M671 X-33:310 Y150:150 S10 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis; Miscellaneous
M911 S10.0 R11.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000
M501 ; load saved parameters from non-volatile memoryFirmware 3
Config.g
; generated by RepRapFirmware Configuration Tool v2.1.3 on Mon Dec 09 2019 11:47:20 GMT+0000 (Greenwich Mean Time); General preferences
M550 P"X5s Duet" ; set printer nameM667 S1 ; select CoreXY mode
M569 P4 S0
M203 X18000.00 Y18000.00 Z1800.00 E1800.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z500.00 E10000.00 ; set accelerations (mm/s^2)
M208 X-17 Y-27 Z0 S1 ; set axis minima
M208 X310 Y310 Z400 S0 ; set axis maxima; Endstops
M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
M574 Y1 S0 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.e6heat" ; create servo pin 0 for BLTouch
M558 P9 C"zprobe.in+zprobe.mod" H10 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P100 X37 Y-3 Z0 ; set Z probe trigger value, offset and trigger height
M557 X5:305 Y5:305 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T10000 B3988 ; configure sensor 0 as thermistor on pin bedtemp
M307 H0 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit; Fans
M950 F0 C"fan0" Q1000 ; create fan 0 on pin fan0 and set its frequency
M106 P0 C"Part" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M950 F1 C"fan2" Q1000 ; create fan 1 on pin fan2 and set its frequency
M106 P1 C"Tool" S0 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on; Tools
M563 P0 D0 H1 F0:1 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossThank you all.
Please read the wiki page on connecting a Z probe. I updated the BLTouch instructions to cover RRF3 a week or two ago.
Oh awesome i somehow missed that,
Okies that makes more sense then.
Only thing i am having trouble is with the M950 S0 C"duex.e6heat"
I dont have the deux bored so i have wired it to pin 31
the wiki says it pin name is.
exp.heater7, exp.31, !duex.e6heat, !duex.pwm5
would any work or would i ahve to use exp.heater7?Sorry for all the questions. I just like to be sure.
Oh just a thought the Z Probe Mod pin could the could i connect the yellow wire to Z Probe Mod and use M950 S0 C"zprobe.mod" instead of pin 31?
@SLKittie said in Firmware 2 to 3 with BLTouch Help.:
You don't have a DuetX so you are connecting directly to the expansion header. Therefore you should use exp.heater7 or exp.31.
I assumed so, but better for clarification.
Thank you so much for the time and help.
