    Did I kill my Duet Maestro
    428
    • markaiundefined
      markai
      Hello thanks for the quick reply.
      Everything looks fine. I was sure when I read something about the blown up MOSFET it must be this part because the smoke was close to the Port. But after checking I think the MOSFET is still okay.
      The wiring should be okay. There is just a possibality that something was wrong with one endswitch wire or the positiv heatbed wire, because that came lose while changing the side of the printer. But I soldered it back on the Heat Bed before reconnecting to the board and powering it up.
      My system runs on 12V.
      Tomorrow I will get a new small Micro SD Card and will look if the board is booting with it.
        When you connect 12V power with nothing else connected to the Duet (no USB), do the red 5V, green 3.3V and blue VIN LEDs light up?
        • markaiundefined
          markai
          Hello @dc42
          I just tried to just hook up 12V and ground. Like you said the three LEDs light up. I also bought a new SD Card. The Controll finds it but I wasn't able to Boot up yet.
          Best regards
            dc42 administrators @markai
            @markai said in Did I kill my Duet Maestro:
            Hello @dc42
            Best regards
            Please explain what you mean by "The Controll finds it but I wasn't able to Boot up yet.". How do you know that the controller finds it?
            Have you gone through https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond ?
            As all 3 LEDs light up, it sounds that U3 is still working. maybe the component that the smoke came from was a fan mosfet - does any of them look damaged?
            • markaiundefined
              markai
              so if I connect the Maestro via USB to my computer I find the COM port in YAT. I can also type in the M-commands. M39 is giving me the capacity of the SD-Card and M503 shows me the firmware. With M552 I can set the Ethernet but if I connect the Ethernet cable nothing happens. I can't start up the webserver. That's what I mean with I can't boot it up.
                A Former User
                if you run just M552 after connecting the cable you get the IP address of the board?
                and what error does your browser give you when trying to access the IP? Timeout or HTTP/404 Not found?
                (Edit: if the SD card got corrupted, did you download the Duet web control files and put them in /www on the new SD card?)
                  • Do the LEDs on the Ethernet socket flash?
                  • Are you able to ping the IP address of the Duet?
                  • Is the W5500 network chip on the Maestro getting hot?
                  markaiundefined 1 Reply Last reply Reply Quote 0
                  • markaiundefined
                    markai @dc42
                    @dc42 @bearer
                    sorry I was on vacation, so I couldn't work on it.
                    I replaced the SD Card and structured the folders like on the documentation written.
                    If I run the M552 Code I see following:
                    M552
                    Network is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                    ok
                    But with M552 S0 i cann't disable the network adress. There are no LEDs flashing when I connect an Ethernet Cable. I just looked closer to the W5500 and it looks like that there is a crack in the chip.
                      It sounds to me that you had a short between +3.3V and something else, and that blew the SD card and the W5500 chip. Those two components are the ones most often blow when there is over voltage on +3.3V.
                      • markaiundefined
                        markai @dc42
                        A okay but that W5500 seems to be really hard to replace. So I guess I have to purchase a new one.
                        Would you recommend me to buy the Duet 2 Wifi. Because there are acctual fuses on it?
                          It's not that hard, an SMD hot air station or ChipQuik will remove the old one. Which country are you in? There may be a repair facility in your country.
                          However, I suggest you check the wiring carefully first, to avoid the same thing happening again.
                          • markaiundefined
                            markai
                            I'm from Germany.
                            So you think it could be possible to repair the board.
                            I will defintly check everythink before powering up.
                            • Vetiundefined
                              Veti @markai
                              @markai
                              if you have a local CCC i am sure they will help if you provide the components and a box or two of club mate.
