    Duet Wifi 2 connected to network, but unable to access DWC
    Duet Web Control
    • LanguidLlamaundefined
      LanguidLlama
      Like the title says I have it connected via USB to my computer through YAT. When I run M552 I get "ok<LF>WiFi module is connected to access point My Eero, IP address 192.168.1.17<LF>"
      When I type in that IP address nothing connects. The DWC Test page also does not work.
      My computer is connected to the same network
      My android phone will not connect either
      I've used Chrome and Edge
      I've tried
      Restarting the Duet
      Restarting computer
      restarting the router
      Deleting the network and re entering ssid and password
        dc42 administrators @LanguidLlama
        Can you ping that IP address from your PC?
        LanguidLlamaundefined 1 Reply Last reply Reply Quote 1
        • Vetiundefined
          Veti
          some router disallow the communication between networks, or even between wireless clients.
          for example sometimes called guest network isolation.
            droftarts administrators
            Looks like you're using and Eero, so I'd think you would have to add it to the list of known devices by giving it a 'nickname' and assign a device group to make it accessible. See https://support.eero.com/hc/en-us/articles/211096103-How-do-I-identify-the-devices-on-my-network-and-assign-nicknames-
              LanguidLlama @dc42
              @dc42 the ping does not go through
                LanguidLlama @droftarts
                @droftarts This is probably pretty close to the problem. I thought it probably had something to do with the network. Unfortunately I am not the owner of the network, so it'll take some back and forth to get this done. Thanks for your help, it is much appreciate. I will report back when I get it working.
                  LanguidLlama
                  Figured it out. both my computer and cell phone were in "Public network mode" and wouldn't communicate with other devices on the network. Thanks for the help, probably wouldn't have figured it out without it.
