    Magnetic Filament detector: stock level and vs laser
    Filament Monitor
    • JuJuDeltaundefined
      JuJuDelta
      https://www.duet3d.com/MagneticFilamentMonitor
      When will this item be back in stock ?
      I have the laser filament monitor.
      Is this as good as the magnetic one, or just for filament out/jam detection ?
      i.e. can the laser be used to compensate/regulate extruder ?
      Many thanks,
      J.
      T3DP3D Kossel XL+, Duet2Wifi, PanelDue 7i, RRF V3.2, Fl3xdrive, SmartEffector, Berd Air annulus, Cura 4.x, PrusaSlicer, RPi WiFi Camera, Heated Chamber
        T3P3Tony administrators @JuJuDelta
        @JuJuDelta
        We have received more stock but need to test and program them before listing.
        The laser sensor is sensitive to the type of filament you use, PETG especially has issues.
          JuJuDelta
          <BUMP>
          Do you have an update of when this will be available ?
          This item still showing out of stock
          https://www.duet3d.com/DuetAddons/MagneticFilamentMonitor
          Thanks,
          J.
