    backing out from the endstop
    864
    • nraynaudundefined
      nraynaud
      here is my free0.g (axis W is the cam shaft):
      G91 ; relative positioning
      G0 Z2 ; lift Z
      G1 E-20 F10000
      G90 ; absolute positioning
      M913 Y180 X180; bump Y axis current
      G53 G0 X212.5 Y0 F40000 ; get in front of the dock
      M208 Y-70 S1 ; Set axis minimum
      G53 G0 Y-55
      G53 G1 Y-66 W11 F10000
      G53 G1 Y-55 F2000
      M913 Y100 X100; restore Y axis current
      M208 Y0 S1 ; Set axis minimum
      G53 G0 Y2 F40000
      here is my tpre0.g:
      G0 Z2 ; lift Z
      G53 G0 X212.5 Y2 F40000
      G53 G1 Y-10 F500 H1 ; re-home Y
      M913 X180 Y180; bump axis current
      G53 G0 Y-60 W1 F40000 ; move and unlock dock
      G53 G1 Y-66 W1 F10000
      here is the tpost0.g:
      M98 P"tpostall.g"
      G1 E20 F8000
      and the tpostall.g:
      M703 ; load filament parameters
      G1 Y-60 F40000
      M913 X100 Y100; axis current
      G53 G0 Y2 F50000; move back
      G53 G1 H1 F500 Y-10 ; home Y
      G53 G0 X200 F50000 ; go towards the prime tower
      my problem is that some steps might be skipped during those operations, either hitting the dock or pulling on the springs, and I want to be able to recover without losing time in the cases where I don't need to recover.
      I was looking into stall detection, but I don't feel confident I can detect it reliably.
      Of course with a cam shaft there is no hard stop, so finding the angular position is normally done by edge triggering.
      the general design is visible here: https://twitter.com/nraynaud/status/1203771796929044480
        dc42 administrators @nraynaud
        @nraynaud said in backing out from the endstop:
        thanks, the backoff is what I do currently.
        What do you think of G1 H parameter that would guard the move (stop when a endstop is triggered or released, why not 2 options) but not change the origin (and we'll do whatever G92 we want from there).
        I don't advise using G92 in homing files, because if the G1 H1 move fails to trigger the endstop, it doesn't set the homed status so the machine is safe from doing ordinary moves; but if you use G92 then the axis gets flagged as homed anyway.
        nraynaudundefined 1 Reply Last reply Reply Quote 0
        • nraynaudundefined
          nraynaud @dc42
          @dc42 I think that makes the window of usefulness quite narrow.
          It seems that stall detection with R3 crashes if it happens in tfree.g, it looks paused, but no button does anything (homing, resuming, cancel print).
          • Danalundefined
            Danal
            The kinematic coupling is different, as is the cam lock... but the X/Y moves to free, pick up, etc. are the same as a Jubilee.
            • Hitting the dock? When I was commissioning the Jubilee, I hit the dock a lot, and therefore un-set Y home. It was very frustrating. However, hitting the dock absolutely stops happening once you get the printer set up correctly.
            • Skipping steps pulling on the spring? Then the spring needs to be weaker or the motor stronger.
            Having a condition where a printer skips steps, and then attempting to compensate for that, represents a fundamental flaw in an open loop design. I realize that is a very direct statement, and it is not meant to be negative. It is, however, meant to push the idea very hard. Either get the operation of the printer to where steps are never skipped, or go to servos.
            • nraynaudundefined
              nraynaud @Danal
              @Danal I am trying to close the loop, that's what all my questions about reacting to switches and conditions and stall detection are.
              I am trying to be progressive in closing the loop, because it's the fastest way to drain money and bringing noise into a system. So for now I'm trying to react to slow filterable events.
              • nraynaudundefined
                nraynaud
                I cobbled something together, I don't know how far it will go:
                outdanger.g:
                M574 Y0 C"nil"
                M558 K0 P5 C"ystop" F10000 H0 I1
                G38.5 Y100 P0
                M558 K0 P0 C"nil"
                M574 Y1 S0 P"!ystop"
                it occurred to me that the endstops are useless most of the time anyways since there are no guarded move, I might even plug them to the emergency stop in normal situation and back to endstops during homing.
                • Danalundefined
                  Danal @nraynaud
                  I do (still) think that servos are the real answer... at the same time... I will do everything I can to help.
                  I've had that same thought. Perhaps wire to both, with a relay (or transistor) to break the path to e-stop when homing?
                  • nraynaudundefined
                    nraynaud
                    my 1000 feet view it to wire them to a M999 script, because the capacitors in the DC power supplies pack a lot of puch and they really don't stop quickly.
                    • nraynaudundefined
                      nraynaud
                      I have significantly reduced the tool changing forces by using this wonderful and clever invention: grease. I should use it more on my moving parts.
                      I have had very good positional repetition and no stalling since.
                      I am posting a picture because I really needed a lucky break on this project.
                      • Danalundefined
                        Danal
                        Nice!!!
                        It is a great feeling to get a multi-color print.
