    Not sure how to set the BLtouch Probe in RepRap 3
    989
      A Former User
      Hi! This is probably a stupid question, but I cannot get the BLTouch to work after upgrading to from RepRap 2 to 3. Whenever I try to use the BLTouch I get "Error: M280: Invalid gpio port 64"
      I have a duet Maestro, and used the RepRap Configurator to setup the new version. I was not able to find out what "PWM Control Channel (BLTouch only)" setting was for, So I left it Blank. I wired the BLtouch as shown in the wiki, and It worked in Reprap 2. I configured it as shown. Annotation 2019-12-23 143838.png
      • Vetiundefined
        Veti
        see
        https://forum.duet3d.com/topic/13285/maestro-with-rrf3/2?_=1577126341583
          You should also refer to this guide for manual configuration. I don't think the config tool is currently up to date for this.
          https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_RepRapFirmware_Num_3
            Post your config.g if you'd like some specific help on what to change.
              A Former User
              ; Configuration file for Duet Maestro (firmware version 3)
              ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 15 2019 20:30:18 GMT-0500 (Eastern Standard Time)
              G90                                                ; send absolute coordinates...
              M83                                                ; ...but relative extruder moves
              M550 P"Aiden's 3D Printer"                         ; set printer name
              M551 P"[REDACTED]"                                  ; set password
              M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
              M586 P0 S1                                         ; enable HTTP
              M586 P1 S0                                         ; disable FTP
              M586 P2 S0                                         ; disable Telnet
              M569 P0 S0                                         ; physical drive 0 goes backwards
              M569 P1 S0                                         ; physical drive 1 goes backwards
              M569 P2 S0                                         ; physical drive 2 goes backwards
              M569 P3 S1                                         ; physical drive 3 goes forwards
              M584 X0 Y1 Z2 E3                                   ; set drive mapping
              M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z400.00 E94.00                   ; set steps per mm
              M566 X480.00 Y480.00 Z24.00 E300.00                ; set maximum instantaneous speed changes (mm/min)
              M203 X18000.00 Y18000.00 Z300.00 E1500.00          ; set maximum speeds (mm/min)
              M201 X1500.00 Y1500.00 Z100.00 E10000.00           ; set accelerations (mm/s^2)
              M906 X1020 Y1020 Z1020 E1020                       ; set motor currents (mA)
              M84 S0                                             ; Disable motor idle current reduction
              M208 X0 Y0 Z0 S1                                   ; set axis minima
              M208 X200 Y200 Z180 S0                             ; set axis maxima
              M574 X1 S0 P"!xstop"                               ; configure active-low endstop for low end on X via pin !xstop
              M574 Y1 S0 P"!ystop"                               ; configure active-low endstop for low end on Y via pin !ystop
              M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
              M950 S0 C"e1heat"                                  ; create servo pin 0 for BLTouch
              M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000      ; set Z probe type to bltouch and the dive height + speeds
              G31 P500 X-36 Y-42 Z0.46                           ; set Z probe trigger value, offset and trigger height
              M557 X36:200 Y42:200 S20                           ; define mesh grid
              M308 S0 P"bedtemp" Y"thermistor" T100000 B3988     ; configure sensor 0 as thermistor on pin bedtemp
              M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
              M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
              M307 H0 B0 S1.00                                   ; disable bang-bang mode for the nozzle heater and set PWM limit
              M308 S1 P"e0temp" Y"thermistor" T100000 B3988      ; configure sensor 1 as thermistor on pin e0temp
              M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
              M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
              M307 H1 B0 S1.00                                   ; disable bang-bang mode for the nozzle heater and set PWM limit
              M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
              M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
              M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
              M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
              M563 P0 S"Extruder" D0 H1 F0                       ; define tool 0
              G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
              G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
              T0                                                 ; select first tool
              • Vetiundefined
                Veti
                @CaptainSnowball said in Not sure how to set the BLtouch Probe in RepRap 3:
                change to
                M950 S0 C"zprobe.mod" ; create servo pin 0 for BLTouch
                M558 P9 C"zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  Phaedrux Moderator @A Former User
                  M558 P9 C"^zprobe.in" H5 F120 T6000
                  And then your M280 command would use zprobe.mod I believe.
                    The documentation isn't currently clear, so I'm not sure if the Maestro requires the ^ in M558 or not, but Veti is very probably right.
                      A Former User
                      I got the same result with and without it.
                      either way, the Z probe does not deploy, and I have to Halt it to prevent it from crashing into the glass.
                      If someone could fix this as well, that would be amazing. it is the deployprobe.g file
                      ; deployprobe.g
                      ; called to deploy a physical Z probe
                      M280 P0 S10 ; deploy BLTouch
                      • Vetiundefined
                        Veti
                        dont home but test M280 P0 S10 manually first.
                        can you try with
                        M950 S0 C"^zprobe.mod"
                          A Former User @Veti
                          So I added
                          to the end of the config.g file and now everything works fine.
                          Thanks everyone!
