Some help with Bltoutch
This is what i got when i redid the config, and but in the right values for the bed and nozzle. and pin 8 is heater 3 or am i wrong ?
; generated by RepRapFirmware Configuration Tool v2.1.4 on Fri Dec 27 2019 22:36:43 GMT+0100 (centraleuropeisk normaltid); General preferences
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes forwards
M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm
M84 S20 ; Set idle timeout; Axis Limits
M208 X300 Y300 Z400 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; set endstops controlled by probe; Z-Probe
M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 H5 F120 T3900 ; set Z probe type to bltouch and the dive height + speeds
M557 X20:280 Y75:270 S20 ; define mesh grid; Heaters
M305 P0 T100000 B4092 R4700 ; set thermistor + ADC parameters for heater 0
M143 H0 S100 ; set temperature limit for heater 0 to 100C
M305 P1 T100000 B4725 C7.060000e-8 R4700 ; set thermistor + ADC parameters for heater 1
M106 P1 S1 I0 F500 H1 T180 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T180 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
hehe i missread your post a bit, about heater 3 and 4, that was one of the mistakes i made i can see now
@Chrabban
is it working now? -
sadly no, the prob is just sitting there red and inside, it wont drop, it started to go down and wanted to probe but that is not a good idea if the prob hasent droped so i had to turn it of so it dosent destroy my bed
Please post your homez.g, homeall.g, deployprobe.g and retractprobe.g files.
okey
; homez.g
; called to home the Z axis
G91 ; relative positioning
G1 H2 Z5 F3900 ; lift Z relative to current position
G90 ; absolute positioning
G1 H2 X20 Y75 F3900 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 H2 Z5 F65 ; lift Z relative to current position
;G90 ; absolute positioning; homeall.g
; called to home all axes
G1 H1 X-305 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F3900 ; go back a few mm
G1 H1 X-305 Y-305 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H2 X20 Y75 F3900 ; go to first bed probe point and home Z
;G1 S2 Z5 F65 ; lift Z relative to current position
;G90 ; absolute positioning; deployprobe.g
; called to deploy a physical Z probe
M280 P3 S10 ; deploy BLTouch; retractprobe.g
; called to retract a physical Z probe
M280 P3 S90 ; retract BLTouch -
@Chrabban said in Some help with Bltoutch:
M280 P3 S10
so when you issue this command manually nothing happens?
there have been many reports with bad cabling on the bltouch side. check the crimp job of those wires.
Nothing happens when i try that command
Allt the cables is good, just tried them with my multimeter -
And you're certain you're using heater pin 3 as the servo control pin?
And you're certain you have the heater pin 3 unbound as a heater in config.g?
And you're certain you have no commands for heater pin 3 in config-override.g? -
As you are not using a DueX expansion board, you need to add parameter I1 (that's letter-i digit-1) to the M280 commands in deployprobe.g and retractprobe.g. See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet_running_RepRapFirmware_Num_2.
it is working now it was the I1 that was the last thing, tnx for all the help
