    Duet3 wifi bltouch wiring
    360
    • bjbeareundefined
      bjbeare
      Using the wiki page https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe, I have connected my bltouch on IO_7 connector: io7.in, io7.out, gnd (black and brown), 5v. For software, I used the configuration tool and set: Input Pin io7.in, Modulation Pin io7.out, PWM Control Channel (OUT7). I also set endstop to z-probe, bltouch.
      I suspect that the PWM control channel OUT7 is incorrect. It seems that the schematic isn't released yet... but my guess is that one of the PWM pins has an optional output on io7.out. Is that right? Which one?
      Love to get the schematic so that I can figure these things out for myself :).
      Could you update the wiki page to provide this info?
      Thank you,
      Bruce
      bjbeareundefined 1 Reply Last reply Reply Quote 0
      • bjbeareundefined
        bjbeare @bjbeare
        @bjbeare To be clear... I am using Duet3 6HC.
        • Vetiundefined
          Veti
          @bjbeare said in Duet3 wifi bltouch wiring:
          did you invert the pwm signal?
          • bjbeareundefined
            bjbeare
            Just tried that. Thank you. It didn't seem to make a difference. Here is the current config.g bits.
            M574 X1 S0 P"!^io0.in" ; configure active-low endstop for low end on X via pin !^io0.in
            M574 Y1 S0 P"!^io1.in" ; configure active-low endstop for low end on Y via pin !^io1.in
            M950 S0 C"!out7" ; create servo pin 0 for BLTouch
            M558 P9 C"io7.in+io7.out" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
            • Vetiundefined
              Veti
              can you try
              M950 S0 C"!io7.out" ; create servo pin 0 for BLTouch
              M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              • Luke'sLaboratoryundefined
                Luke'sLaboratory
                M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                M558 P9 C"io7.in" H10 F120 T3600 ; set Z probe type to bltouch and the dive height + speeds
                I have a functional BLtouch on io7 with these commands.
                Luke
                http://lukeslab.online
                • bjbeareundefined
                  bjbeare
                  @Luke-sLaboratory said in Duet3 wifi bltouch wiring:
                  The bltouch flashes and probe does not deploy.
                  ; deployprobe.g
                  ; called to deploy a physical Z probe
                  ; generated by RepRapFirmware Configuration Tool v2.1.4 on Sun Dec 29 2019 09:17:44 GMT-0800 (Pacific Standard Time)
                  M280 P0 S10 ; deploy BLTouch
                  ; retractprobe.g
                  ; called to retract a physical Z probe
                  M280 P0 S90 ; retract BLTouch
                  M550 P"Duet 3" ; set printer name
                  M667 S1 ; select CoreXY mode
                  M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
                  M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
                  M84 S30 ; Set idle timeout
                  M208 X450 Y450 Z450 S0 ; set axis maxima
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                  M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                  M307 H1 B0 S1.00 ; disable bang-bang mode for the nozzle heater and set PWM limit
                  M950 F0 C"out8" Q500 ; create fan 0 on pin out8 and set its frequency
                  M950 F1 C"out9" Q500 ; create fan 1 on pin out9 and set its frequency
                  • Vetiundefined
                    Veti @bjbeare
                    if it fails the self test on powerup, something else is wrong.
                    did you try the inversion?
                    • bjbeareundefined
                      bjbeare
                      These suggestions have been good. I'm able to send commands now and get the probe to deploy/test/retract. I'm still getting a flashing indication during homing and homing is failing. Working the issue.
                      Luke'sLaboratoryundefined 1 Reply Last reply Reply Quote 0
                        Luke'sLaboratory @bjbeare
                        @bjbeare
                        Thanks for reporting back!
                        Sounds like a wiring issue or something with the ferrous core positioning -
                        Is it mounted straight in reference to gravity? Sometimes they bind funny
                        Luke
