    How do i connect IR Z probe from pibot 5V
    1.1k
    • StefaanCundefined
      StefaanC
      Hello , i order yesterday duet wifi control board , my previous was geeetech GT 2560 with pibot 5V rev1.3 IR Z probe
      now i read , that endstops are 3.3 volt do i need to place a resitor between ground and signal ? i did not on my geeetech board.
      To take 5 volt from the board what connector do i have to use ?
      kind reagards stefaan
        If the pibot won't work on 3.3V then you will need to use a 1:2 potential divider to reduce the output to 3.3V. Suitable resistor values would be 5.1K and 10K. You can get +5V from the PanelDue connector or from pin 1 of the expansion connector.
        • StefaanCundefined
          StefaanC
          Hello i put te resistors in place the ir sensor is powerd red led , when i come close to it it give a bleu led , it see my finger.
          but when i send M119 gives : Zprobe not stopped ! it is connected on the Zprobe connector 2 wires: 1 Gnd ,1 Zprobe in.
          doe i need doe some g code to let work this probe ?
          Are did i used the wrong board connector ?
          Wifi works Perfect . connection with browser works super too !
          Kind regards stefaan
            You will need to connect it to the Z probe connector and use M558 P1 in your config.g file.
            • StefaanCundefined
              StefaanC
              Hello ; verry strange the pibot ir sensor normally need 5 volt , i did the capacitors away en connect to 3,3v and and sig , en the sensor works when trigger it gives around 643 in pink color , i just did the calibration and get this value : Calibrated 6 factors using 10 points, deviation before 2.979 after 0.351
              Is this a good sign ? after this calibration do have to save this ? so yes how do i do this .
              kind regards stefaan
              thank you for your replies .
                https://duet3d.com/wiki/Calibrating_a_delta_printer
