CR-10S Duet Wifi homing
I am having issues with the homing my motors. I had used the home all but my motors only move ever so slightly, and also it doesn't move to the end switch for the X,Y. Been trying to figure this out all day. At this point im at a lost and need some direction on how to handle this.
Start by confirming the limit switches work correctly. Observe the LEDs as you press them, or press and hold one while you run
M119
- repeat for all. -
i finally was able to get the x,y working. i had them on the wrong pins. Do you happen to know how to configure the BL-touch? i am able to deploy the pin up/down but i dont know how to update the Home.g to utilize it. Thank you again.
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe also links to testing and calibrating.
