    Error when create filaments profils
    Duet Web Control
    • StAnZ-007undefined
      StAnZ-007
      Sorry for my english, in general I speak french...
      So, my problem appear when I try to create new filaments, the system didn't find "filaments" directory, I try to create directly by Duet_Web_Control interface, don't work.
      Then I remove the SD card from the Duet and put it in my PC, I create the "filaments" directory manualy, don't work...
      I delete and create a second time the "filaments" directory by Duet_Web_Control interface and restart the board.
      After that, when I try to create a new filamant, the system said that he can't create the directory "PLA" from my exemple below.
      What is wrong in my process ?
      Thanks for your help.
      Here is the error message :
        Put the SD card in your PC and create a folder called 'filaments'.
          StAnZ-007
          @Phaedrux said in Error when create filaments profils:
          In sys directory or in root directory ?
          I found the 2 informations in the forum...
          Thanks
            in the root of the SD card
              StAnZ-007
              OK, it's working when the "filament" folder is created in root, not in sys directory.
              Thanks
