    syncronizing 2 z-steppers
    22
    884
    • spllgundefined
      spllg @SLKittie
      @SLKittie said in syncronizing 2 z-steppers:
      From my understanding. you are trying to say the the Z endstop and probe is io5.in and
      Do you have a z endstop and probe?
      i only have a probe and use it successfully for z-homing and want to use it as z-probe as well.
      if you have both then i think you need to use diffenrt pins and codes.
      I dont have the Duet 3
      so cant confirem but i dont think you can use the same pin for both Z endstop and Probe.
      that's what i'm afraid of. so, should i try to connect io5.in to io6.in and use io5.in as zstop and io6.in as z-probe? any opinions?
      • SLKittieundefined
        SLKittie
        You may need to have a look at these websites as you dont have the configerastion for the probe set up. as there is no G31 command after your M558 to say where the prob is and how to activae it.
        https://duet3d.dozuki.com/Wiki/Setting_up_automatic_probing_of_the_print_bed
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        Just out of curiosity how do you code your Config.g?
        spllgundefined 1 Reply Last reply Reply Quote 0
        • spllgundefined
          spllg @SLKittie
          thanks for the hints - going to read tomorrow (i find it hard to get started because i feel information is kind of scattered)
          initial version was generated by a reprap website (i have forgotten the url)..
          do i really need distinct z-endstop and z-probe? i cannot believe this.
          dc42undefined Danalundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @spllg
            @spllg said in syncronizing 2 z-steppers:
            If you use the Z probe to home Z then you don't need a Z endstop. https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
            spllgundefined 1 Reply Last reply Reply Quote 1
            • Danalundefined
              Danal @spllg
              I use a single microswitch, defined as a probe, to both home and auto-bed-level (three motors) and mesh probe a bed on a CoreXY.
              So, define a probe for Z, and don't define an endstop for Z, and it "just works".
              Jaw8850undefined spllgundefined 2 Replies Last reply Reply Quote 0
              • Jaw8850undefined
                Jaw8850
                I'm doing same thing, I did have to define Z-Probe in my config.g though. I'm having issue with 1 side dropping but I don't believe it is related to the issue you're having. Here is my config G and you can see Z-Probe settings
                ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 07:12:07 GMT-0500 (Eastern Standard Time)
                M550 P"Alex's Hypercube" ; set printer name
                M667 S1 ; select CoreXY mode
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M584 X0 Y1 Z2:4 E3 ; set drive mapping
                M671 X-30:330 Y156:156 S1.5 ; leadscrews at left and right
                M92 X161 Y160 Z809 E819 ; set steps per mm
                M203 X18000.00 Y18000.00 Z300.00 E350 ; set maximum speeds (mm/min)
                M201 X3000.00 Y3000.00 Z100.00 E350 ; set accelerations (mm/s^2)
                M906 X1400 Y1400 Z1400 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X0 Y0 Z-5 S1 ; set axis minima
                M208 X280 Y280 Z370 S0 ; set axis maxima
                M591 D0 P5 C3 R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                M558 P1 XO YO H3 F200 T9000 B1 R0.1 A5 ; set Z probe type to modulated and the dive height + speeds
                G31 P500 X-27 Y0 Z1.650 ; set Z probe trigger value, offset and trigger height
                M557 X20:240 Y20:260 S220 ; define mesh grid
                M305 P0 T100000 B4725 C7.06e-8 ; set thermistor + ADC parameters for heater 0
                M307 H1 A390.9, C258.2, D5.4, S1 ; hot end thermister tuning
                M305 P1 T100000 B4725 R4700 ; set thermistor + ADC parameters for heater 1
                M106 P2 S0.5 I0 F500 H1 T45 ; set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                Here is my bed.g
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool v2.1.4 on Tue Dec 24 2019 07:12:06 GMT-0500 (Eastern Standard Time)
                G28 ;home
                G30 P0 X0 Y156 Z-99999 ; probe left leadscrew
                G30 P1 X260 Y156 Z-99999 S2 ; probe right leadscrew and calibrate 2 motors
                G29 ; run mesh bed leveling
                • Jaw8850undefined
                  Jaw8850 @Danal
                  @Danal this sounds interesting, do you have any pictures so I can get an idea of how to maybe adapt this to mine. I currently run a DC42 IR sensor and I think it may not be the most reliable and a BL touch has more wires and I already have a 22 pin connector full on my X carriage and don't have room to run the extra 2 for the BL Touch neatly so this may give me a better option.
                  • Danalundefined
                    Danal
                    I will get a pic... but the microswitch is just on the bottom of the carriage that grabs tools (this is a toolchanging printer).
                    Definition statements for all endtstops and probes:
                    ; Endstops and probes
                    M574 X1 S1 P"io1.in"                    ; Set homing switch configuration X1 = low-end, S1 = active-high (NC)
                    M574 Y1 S1 P"io2.in"                    ; Set homing switch configuration Y1 = low-end, S1 = active-high (NC)
                    M574 U1 S1 P"io3.in"                    ; Set homing switch configuration U1 = low-end, S1 = active-high (NC)
                    ;M574 Z1 S1 P"!io4.in"                   ; Set homing switch configuration Z1 = low-end,  S1 = active-high (NC).  This is used for tool probing, not actual Z height.
                    M558 K0 P5 C"io4.in" H5 A5 T6000 S0.02   ; Z probe - Set the height of the bed when homing G28.  Combined with content of bed.g as invoked by G32, levels bed. Also used for Mesh.
                                                               ; P5 = Switch, NC
                                                               ; C  = Input Connector
                    					   ; Hn = dive height
                    					   ;   A bigger dive height prevents a situation where the bed is out of alignment by more than the dive height
                    					   ;   on any corner, which can crash the hot-end into the bed while moving the head in XY.
                    					   ;   Probing speed and travel speed are similarly reduced in case the Z probe isn't connected properly (or
                    					   ;   disconnects later after moving to a point) giving the user more time to stop.
                                                               ; An = Number of times to probe each point.
                                                               ; Tnnn = Travel speed between probe points.
                                                               ; Snnn = Tolerance when probing multiple times. Two readings inside this window and we move on.
                    • spllgundefined
                      spllg @dc42
                      @dc42 thank you very much for this valuable hint.
                      • spllgundefined
                        spllg @Danal
                        @Danal i do not have a z-endstop mounted near the nozzle - i don't hav a z-endstop at all.
                        dc42's hint solved my issue.
