    RepRapFirmware 3.0beta12 now available
    Beta Firmware
    16
    38
    2.5k
    • keyz182undefined
      keyz182
      New issue - porting over my sensorless homing settings.
      config.g
      M915 X Y S4 F0 H200 R1
      homeall.g
      M913 X45 Y45		; drop motor currents to 45%
      M915 X Y S4 R0 F0     	; set X and Y to sensitivity 2, do nothing when stall, unfiltered
      G1 H2 X20 Y20 Z5 F6000  ; lift Z relative to current position
      G1 H1 X-281 Y-325 F6000 ; move quickly to X or Y endstop and stop there (first pass)
      G4 P150
      G1 X20 Y20            	; move away from home
      G4 P150
      G1 H1 X-281 F3600       ; home X axis
      G4 P150
      G1 H1 Y-325 F3600       ; home Y axis
      G4 P150
      G1 X20 Y20 F6000        ; go back a few mm
      M400                  	; make sure everything has stopped before we reset the motor currents
      M913 X100 Y100		; reset motor currents
      G90                     ; absolute positioning
      G1 X125 Y150 F3600      ; Move to bed centre
      G4 P500                 ; pause
      ; BLTouch Z
      G30 			; Do a single probe to home our Z axis
      G90 			; Make sure we are in absolute mode
      G1 Z10 F360 		; Rapidly move the Z axis to Z=10.
      It gets up to the second G1, but as soon as it hits an axes (aka the "endstop") it stops homing and ignores the rest of the script.
        There is a known issue with stall detect homing in the RRF3 beta releases up to and including beta 12. The more recent build on Dropbox includes a change that may fix it.
        • keyz182undefined
          keyz182
          Gotcha. The dropbox build also fails in the same way unfortunately.
            dc42 administrators @keyz182
            Thanks, on my list to look at after FormNext.
              @keyz182, is this a Cartesian or a CoreXY machine?
              Please post your complete config.g file.
              keyz182undefined 1 Reply Last reply Reply Quote 0
              • keyz182undefined
                keyz182 @dc42
                @dc42 said in RepRapFirmware 3.0beta12 now available:
                I'm back on 2.04 for now as I had to get some printing done. That's done, so will be able to test 3.0 again this week now.
                Below is the 3.0 config.g I last tested with.
                G90                                                     ; send absolute coordinates...
                M83                                                     ; ...but relative extruder moves
                M550 P"ThreeDee"                                        ; set printer name
                M667 S1                                                 ; select CoreXY mode
                M552 S1                                                 ; enable network
                M586 P0 S1                                              ; enable HTTP
                M586 P1 S0                                              ; disable FTP
                M586 P2 S0                                              ; disable Telnet
                M569 P0 S1                                              ; physical drive 0 goes forwards
                M569 P1 S1                                              ; physical drive 1 goes forwards
                M569 P2 S1                                              ; physical drive 2 goes forwards
                M569 P3 S0                                              ; physical drive 3 goes forwards
                M569 P4 S0                                              ; physical drive 4 goes forwards
                M584 X0 Y1 Z2 E3:4                                      ; set drive mapping
                M350 X16 Y16 Z16 E16:16 I1                              ; configure microstepping with interpolation
                M92 X80.00 Y80.00 Z1600.00 E425.00:425.00               ; set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00:120.00              ; set maximum instantaneous speed changes (mm/min)
                M203 X30000.00 Y30000.00 Z360.00 E7200.00:7200.00       ; set maximum speeds (mm/min)
                M201 X3000.00 Y3000.00 Z20.00 E6600.00:6600.00          ; set accelerations (mm/s^2)
                M906 X1500 Y1500 Z1500 E1200:1200 I30                   ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                                 ; Set idle timeout
                M208 X-1 Y-15 Z0 S1                                     ; set axis minima
                M208 X275 Y305 Z290 S0                                  ; set axis maxima
                ; Stall Detection
                M574 X1 S3                                              ; configure sensorless endstop for low end on X
                M574 Y1 S3                                              ; configure sensorless endstop for low end on Y
                M574 Z1 S2                                              ; configure Z-probe endstop for low end on Z
                M558 P9 C"^exp.heater3" H3 F100 T5000 A5 S0.02          ; set Z probe type to bltouch and the dive height + speeds
                M950 S0 C"exp.e3stop"                                   ; create servo/gpio 0 on endstop 3 pin on expansion connector
                M280 P0 S10                                             ; send control signal to BLTouch through servo/gpio 0
                ;G31 P25 X0 Y0 Z2.55                                     ; set Z probe trigger value, offset and trigger height
                G31 P25 X15 Y33 Z2.55                                     ; set Z probe trigger value, offset and trigger height
                M557 X10:265 Y10:295 S30                                ; define mesh grid
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                                   ; create bed heater output on bedheat and map it to sensor 0
                M143 H0 S120                                            ; set temperature limit for heater 0 to 120C
                M307 H0 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
                M308 S1 Y"rtdmax31865" P"spi.cs1" A"RTD1"
                M950 H1 C"e0heat" T1                                    ; create nozzle heater output on e0heat and map it to sensor 1
                M143 H1 S360                                            ; set temperature limit for heater 1 to 360C
                M307 H1 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
                M308 S2 Y"rtdmax31865" P"spi.cs2" A"RTD2"
                M950 H2 C"e1heat" T2                                    ; create nozzle heater output on e1heat and map it to sensor 2
                M143 H2 S360                                            ; set temperature limit for heater 2 to 360C
                M307 H2 B0 S1.00                                        ; disable bang-bang mode for the nozzle heater and set PWM limit
                ; Sensors
                M308 S3 Y"mcutemp" A"mcutemp"
                M950 F0 C"fan0" Q500                                    ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1 C"PartFan"                               ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                                    ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S0 H1:2 T45 C"ExtruderFan"                      ; set fan 1 value. Thermostatic control is turned on
                M950 F2 C"fan2" Q500                                    ; create fan 1 on pin fan1 and set its frequency
                M106 P2 S0 H3 T45 C"DuetCooling"          	; set fan 1 value. Thermostatic control is turned on
                M563 P0 S"Left" D0 H1 F0                                ; define tool 0
                G10 P0 X0 Y0 Z0                                         ; set tool 0 axis offsets
                G10 P0 R0 S0                                            ; set initial tool 0 active and standby temperatures to 0C
                M563 P1 S"Right" D1 H2 F0                               ; define tool 1
                G10 P1 X0 Y0 Z0                                         ; set tool 1 axis offsets
                G10 P1 R0 S0                                            ; set initial tool 1 active and standby temperatures to 0C
                ; Heater 5 LEDs
                M950 P0 C"exp.heater5"
                M42 P0 S0
                ; Pressure Advance
                M572 D0 S0.02
                ; Retraction Settings
                M207 S0.2 F4800 T4800 Z0.10 		   ; Distance 4.5mm, Speed 6500, de-retract 3500, extra distance 0.025, zhop 0.4
                ;DAA
                M593 F60
                M501                                                    ; load saved parameters from non-volatile memory
                keyz182undefined dc42undefined 2 Replies Last reply Reply Quote 0
                • keyz182undefined
                  keyz182 @keyz182
                  @keyz182 said in RepRapFirmware 3.0beta12 now available:
                  ; Stall Detection
                  ; Sensors
                  ; Heater 5 LEDs
                  M42 P0 S0
                  ; Pressure Advance
                  M572 D0 S0.02
                  ;DAA
                  M593 F60
                  Also, it's CoreXY
                    Thanks. My tests so far on stall detect homing (on my delta) indicate that it is working in RRF3, so I need to replicate your configuration.
                    Are you able to do some more tests?
                      Stall detect homing is working on my tool changer using RRF 3.0 stable, so I will assume this issue is closed.
                      jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                        jay_s_uk @dc42
                        Stall detect works for me too on my tool changer in RRF3
                        • keyz182undefined
                          keyz182 @keyz182
                          ; Stall Detection
                          ; Sensors
                          ; Heater 5 LEDs
                          M42 P0 S0
                          ; Pressure Advance
                          M572 D0 S0.02
                          ;DAA
                          M593 F60
                          Also, it's CoreXY
                          Hi @dc42, apologies, my printer has been inaccessible thanks to "christmas mess" for the last month, so haven't been able to test anything.
                          I'll get 3.0 stable on my machine later this week and give it a whirl 🙂 Thanks!
                            I'm closing this thread ow because it related to an old beta. Please raise any issues with RRF 3.0 stable in new threads.
