    charge pump
    Firmware wishlist
    1.6k
    • DaBitundefined
      DaBit
      As said before, too low a frequency is not desirable; a charge pump circuit should not react to AC line frequencies, you want teh CP line frequency at least a couple of octaves above that so one can separate it with the 6dB/oct rolloff of a single RC.
      @zapta: Love those AFO fireballs, thanks for the tip. I think I buy a few of them and put them inside my machines and above the workbench.
      • zaptaundefined
        zapta @DaBit
        @DaBit, this is the European competitor. More expensive and potentially better quality(?). http://www.elidefire.eu.com/en/the-product
          A Former User @zapta
          @zapta the specification state that for electrical and gas/liquid fire it's monitoring only .. not sure how it will work for 3d printers ... I'd still prefer to cut the power 😄
            A Former User
            Regarding the frequency, I started the (happy!) new year with a somewhat scientific experiment.
            I've hooked up the signal generator to the charge pump input of the Gecko G540, and had a look at what its happy with or not.
            At 50% duty cycle it'll accept from 600Hz and past 100kHz (into Mhz in fact but stopped taking notes at 100kHz).
            At 25% and 75% the range narrowed to 750Hz on the lower end.
            At 12.5% and 87.5% same as 25%.
            At 6.25% and 93.75% further narrowing to about 1khz on the lower end.
            No perceived difference in square, saw, sine or even noise output functions. Its worth noting that once started at say 600Hz/50% it will not fault until the frequency drops below 250Hz or the duty cycle drops below 3%. Hope dc42 finds the data, even if just one datapoint, useful.
              There are two easy outputs that could be provided. One is a square wave at 500Hz, generated in the tick interrupt service routine. The other is a lower frequency, more erratic signal generated by the main task loop. The interval between state changes could rise as high as 200ms when writing to SD card.
              DaBitundefined 1 Reply Last reply Reply Quote 0
                A Former User
                As i said, I only have the one driver with an charge pump input, but that test indicates it'll either be primarily usefull for a DIY receiver or commercial stuff with even grater tolerances to what seems to be the ideal frequency around 10kHz for the CNC crowd.
                But I'll be happy to test it as is ofc.
                  I suspect that most devices that provide a charge pump output at above 500Hz are either generating it in hardware, or are simple devices running a very simple software loop. Generating charge pump signals at high frequencies is not very practical for a complex software system running RTOS. The tick interrupt frequency could be increased by a small factor to generate a charge pump frequency of 1kHz or a little higher, but much more would use up too much CPU time.
                  • zaptaundefined
                    zapta @A Former User
                    @bearer said in charge pump:
                    Do you know how fast it detects that the signal stoped? (e.g. feed 100KHz, 50%, then set a fixed input voltage and measure time to shutdown signal).
                      @zapta said in charge pump:
                      faster than i could observe without a scope, same result if signal went over or under about 3/97% duty cycle or below about 250hz.
                      • DaBitundefined
                        DaBit @dc42
                        @dc42 said in charge pump:
                        A charge pump signal indicating that at least the heater control processes are sane is still high on my wishlist, and I would not mind an erratic signal. Easy to cope with that in chargepump signal processing circuitry, and with a 3D printer I absolutely don't need subsecond reaction times.
                        Should I do an official feature request somewhere?
                          dc42 administrators @DaBit
                          @DaBit said in charge pump:
                          The Heat process runs at intervals of 250ms, so any signal it generates would either comprise short pulses at 250ms intervals, or a 2Hz square wave.
                          There is already a software watchdog in the tick interrupt handler to check that the heat task is active. The tick interrupt handler is monitored by the hardware watchdog.
                          • DaBitundefined
                            DaBit
                            A 2Hz signal would require an approximately 0,2Hz time constant for the CP detection circuitry. Completely acceptable for me. 0,02Hz would be acceptable too. But a 2Hz signal is not very useable with other off the shelf hardware unfortunately.
                            I don't really care where the CP signal is generated and what it's actual frequency is, as long as it is a reasonable reflection of software health state. The tick interrupt handler might be the most convenient place and the most conventient frequency. If it ever proves to be ineffective it can always be improved.
