    [Solved]Confused again about Z-homing Orion probe
    428
    • AlexLinundefined
      AlexLin
      Hi
      I have my Orion quite a while now, but chang from having max z/u endstops to using the probe as z-min.I do this to save time homing.
      I have this in my config.g
      G31 X0 Y0 Z0 P100
      M558 P5 I1 R0.9 F500 X0 Y0 Z0
      and homez.g
      ;homing min using probe
      G91 ; relative positioning
      G1 S2 Z10 F6000 ; lift Z relative to current position
      G90 ; absolute positioning
      G1 X145 Y145 F6000 ; go to first probe point
      G1 Z10 F100 ; lift Z relative to current position
      However after homing it z shows 15.7mm when probing G30 S-1 after homing it always shows 0.7mm..
      I don't understand where the 0.7mm comes from
      as result my prints start to close to the bed(0.6mm)
      What do I do wrong?
      • AlexLinundefined
        AlexLin
        If I manually perform this from the console and then home z it works
        G31 X0 Y0 Z0 P100
        • AlexLinundefined
          AlexLin
          Ok G31 returns
          G31
          Current reading 0, threshold 500, trigger height 0.70, offsets X0.0 Y0.0
          so that explains..but where is the 0.7 coming from? I don't have it in my config.g or any other file..
          • AlexLinundefined
            AlexLin
            Think I found the reason G31 before M558 seems to ignore the G31 setting. Placing it after M558 did the trick
              Phaedrux Moderator @AlexLin
              @AlexLin said in Confused again about Z-homing Orion probe:
              G31 X0 Y0 Z0 P100
              The G31 should come after the M558 in config.g if it isn't already.
              What firmware version?
              M558 X0 Y0 Z0 is deprecated, remove those.
              Can you post your entire config.g?
              • AlexLinundefined
                AlexLin
                thanks for the M558 comment..will remove that
                But yes placing G31 after M558 helps. I cannot find where that is stated though......
                  dc42 administrators @AlexLin
                  @AlexLin said in [Solved]Confused again about Z-homing Orion probe:
                  I've just added it to https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_G31_Set_or_Report_Current_Probe_status.
                  • AlexLinundefined
                    AlexLin
                    excellent!
