    Connecting laser to duet wifi
    Laser Cutters
    1.4k
    • Killerm1undefined
      Killerm1
      I am trying to figure out the best way to connect a laser engraver to the duet wifi using a 24v power supply. The laser I am using is off of this https://www.banggood.com/2500mW-A3-30x40cm-Desktop-DIY-Violet-Laser-Engraver-Picture-CNC-Printer-Assembling-Kits-p-1003863.html?rmmds=search&cur_warehouse=CN
      I have searched and found 2 possible ways:
      https://forum.duet3d.com/topic/4467/laser-engraving-with-duetwifi-connections
      https://forum.duet3d.com/topic/4632/laser-wiring/10
      I am fine with connecting circuits but have no idea when it comes to how the circuits work or designing them. So a solution where I can buy the circuit would be preferable. What would you advise is the best, simplistic way?
      Thanks
      • Killerm1undefined
        Killerm1
        Hello? Anyone able to help please ☝
        • Korbohundefined
          Korboh
          You could feed a 12v through a buck converter (from the same 24v you power the Duet... Google about multiple voltage on Duet you'll see how to do that) to the V_FAN input and then plug the laser to one of PWM Fans output so you'd be able to power the laser from 12V on/off with a simple M106/M107 gcode.
          Hope it helps.
          Killerm1undefined 1 Reply Last reply Reply Quote 0
          • Killerm1undefined
            Killerm1 @Korboh
            @korboh I was wondering if that was possible. Thanks I will look more into that.
            • Killerm1undefined
              Killerm1
              So would this wiring work from pic?
              • otaku521undefined
                otaku521
                Could anyone help pls
                I can’t get the laser to fire
