Solved Delta leveling problem
please execute M98 P"/sys/config.g" and post the output
the issue is that you have defined the Probe input to be on the Z-Probe port but have it connected to the E0 end stop pins so the firmware can't find the probe.
; Z-Probe M558 P4 C"zprobe.in+zprobe.mod" H3 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z16.0 ; set Z probe trigger value, offset and trigger height M557 R115 S20 ; define mesh grid G29 S1 G28
@Dougal1957 said in Delta leveling problem:
Additionally, there is no probe type 4 in RRF3. If the probe is some sort of switch or has an output like a switch, use either P5 (filtered) or P8 (filtered).
i tried this;
; Z-Probe M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z16.0 ; set Z probe trigger value, offset and trigger height M557 R115 S20 ; define mesh grid
the console sends this message; Error: Z probe already triggered at start of probing move
Did you move the wire?
Also, you can invert an input with !. So try
C"!zprobe.in+zprobe.mod"
and variants thereof.
You may also need to enable the pullup resistor by adding the ^ character in front of zprobe.in.
thanks for now!
with;C "! Zprobe.in + zprobe.mod"
the probe collides on the bed
and with;
C "^ Zprobe.in + zprobe.mod"
does not work
the probe is connected in E0 endstop terminal as written in the configurator (if I click the switch the led turns off (e0stp) ) -
I think the code C"zprobe.in+zprobe.mod" is wrong but that's what configurator inserts
@ventu22 said in Delta leveling problem:
thanks for now!
and with;
does not work
the probe is connected in E0 endstop terminal as written in the configurator (if I click the switch the led turns off (e0stp) )Also try combinations. C "!Zprobe.in + zprobe.mod" and/or C "^!Zprobe.in + zprobe.mod"
Most importantly: Did you move the wire? You said you were connected to E0 Endstop pin. That will not work with the C"xxx" you've used. You must connect to the Zprobe connector.
that is inserted because you selected it in the io mapping. there you change those pins.
how to connect the switch in the zprobe connector?
its its a normal NO or NC switch one wire goes to gnd one to zprobe_in
work
thank you all!!!!!
