    IP and MAC address is funky
    450
    • ericlmccormickundefined
      ericlmccormick
      I just installed a Nest Wifi and it sees my MAC address the same as my old router which is 84:f3:eb:82:e2:4a. However when I run the command m540 I get the result of a5:a5:a5:a5:a5:a5.
      In addition, when I go into the Google Wifi app, it says IP addess unavailable but can still do a network test with it, I'm assuming via its MAC address. When I go to the IP address I have been using, I can access the Duet from a web browser. However, since the router isn't showing the IP address, I can't do port forwarding. This is something I need so that I can pause or stop a print remotely if I see an issue while I am away from home.
      My old router was having a similar port forwarding issue and I thought it was the router. Now I think it is the Duet board.
      Please help.
        A Former User @ericlmccormick
        @ericlmccormick said in IP and MAC address is funky:
        run arp -a from windows command line an see what it thinks the mac address is? should be cached for 2-5 minutes after you access the duet with the browser.
        Hmm, dawned on me the MAC address is sort of irrelevant, but while I haven't worked with google wifi products there are a few pieces to the puzzle I'd like to know. (including the output from arp above).
        Is the Duet2Wifi (presumaly?) using a static IP or DHCP?
        Did you have to change the config / SSID when you installed the Nest Wifi?
        Does setting the MAC address manually help? Add M540 P84:F3:EB:82:E2:4A to config.g then reboot the Duet
        I hope by this you mean you have another network with a server running a proxy for the Duet adding HTTPS and access control to things and not exposing Duet Web Control directly to the internet. Bad mojo.
          I confirm that on a Duet WiFi running RRF 3.01beta2, M540 reports the MAC address as all 'a5'. It looks like fetching the MAC address from the WiFi module via M540 was never implemented. The M122 report gives the correct MAC address.
          ericlmccormickundefined 1 Reply Last reply Reply Quote 0
            ericlmccormick @dc42
            I am running 2.04RC4 (2019-10-19b1)
            Running command M122 gives the following
            RepRapFirmware for Duet 2 WiFi/Ethernet version 2.04RC4 running on Duet WiFi 1.02 or later
            Board ID: 08DGM-9T6BU-FG3SN-6JKD8-3SN6R-9VWMG
            Used output buffers: 3 of 24 (10 max)
            Static ram: 25700
            Dynamic ram: 92816 of which 0 recycled
            Exception stack ram used: 268
            Never used ram: 12288
            Tasks: NETWORK(ready,764) HEAT(blocked,1176) MAIN(running,3824) IDLE(ready,160)
            Owned mutexes:
            Last reset 00:08:59 ago, cause: software
            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 12332 bytes (slot 0)
            Error status: 0
            Free file entries: 10
            MCU temperature: min 28.1, current 28.7, max 29.0
            Supply voltage: min 25.2, current 25.3, max 25.4, under voltage events: 0, over voltage events: 0, power good: yes
            Date/time: 2020-01-26 14:37:36
            Cache data hit count 2090006692
            Slowest loop: 2.56ms; fastest: 0.06ms
            Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
            === DDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is idle in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 35.41ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            • WiFi -
              Network state is running
              WiFi firmware version 1.21
              WiFi MAC address 84:f3:eb:82:e2:4a
              WiFi Vcc 3.42, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 15672
              WiFi IP address 192.168.0.104
              WiFi signal strength -57dBm, reconnections 0, sleep mode modem
              @ericlmccormick at least the Duet knows its own MAC address after all, but it doesn't solve your problem unfortunately.
              Does creating a reservation for the MAC and IP combination help?
              https://support.google.com/googlenest/answer/6274660?hl=en
                ericlmccormick @A Former User
                @bearer I can set a IP reservation but it doesn't do anything
                  ericlmccormick
                  I have updated the firmware in the release order to get it up to version: 3.01-beta2 (2020-01-23b1)
                  The issue persist
                    The issue persist
                    M540 issue is only confusing, but not an actual problem. If its set up to use DHCP, and it gets an address, you can access it on your network but doesn't show up in your router then the problem is most likely elsewhere.
                    Would need some sort of wireshark log to say more, but that might prove tricky if on windows.
                      The M540 reporting issue on the Duet WiFi will be fixed in the next 3.01 beta. I have also added the MAC address to the object model.
