Extrude/retract UI in PanelDue and WebUI
Is there a way to modify the steps per mm for these controls? I have installed a Zesty Nimble and the turning ratio from the stepper to the hobbed gear is WAY different from the default setting I used for the E3D tool changer.
Just the UI? No. I believe what you need to adjust is steps per mm on the E0 axis.
M92 Ennn
The extrusion rate in the config for that tool is set correctly for when it is printing. While printing it works fine.
But it is not correct when I use the UI in the panel or the web interfaces. Those must be set somewhere else. -
The UI just issues GCode commands. Pressing the extrude button with the GUI set like the example below issues this sequence:
M120 ;Push M83 ;Extruder relative G1 E10 F300 ;Actual extrusion M121 ;Pop Specifically note the
G1 E10 F300
. This is exactly what would be in a print job. It literally can't be a different steps/mm.So... what symptom are you seeing? If you press the "extrude" button with the amount set to 100, how much do you get? If you execute a G1 E100 F900 via the console, how much do you get? If you make a one line job with the same G1 and run it, how much do you get?
