    Firmware 1.18 provisional change list
    Firmware wishlist
    13
    41
    6.5k
    • InSanityundefined
      InSanity
      Hey I have another perhaps stupid question. Is the idle down percentage applied via the stepper driver chip or is this the firmware applying the settings ? The reason I ask is if the Z-Axis driver wasn't receiving any step commands is it possible it would idle down if say it took over 30 seconds to get the next step command ?
      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
        Currently the current is reduced to the idle value only when no stepper motor has moved for the idle time.
        • InSanityundefined
          InSanity
          @dc42:
          Ok, so it's the firmware telling them to idle down and not the chips themselves ?
            Yes it's the firmware.
            • Simspeedundefined
              Simspeed
              Please keep in mind the 4 motor Z axis upgrade DC….thanks.
              Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
              • jrledererundefined
                jrlederer
                quick question for ya:
                just updated to latest beta 1.18 firmware, eager to test the baby-stepping feature. only thing is don't know how to adjust the newly added function. please advise.
                thanks, in advance, and hope everyone is having a nice day!!
                –jonathan
                "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
                  Currently you send G92 R1 Z# where # is the amount you want to step in mm, in the range -1 to +1mm. I have created two macro files, containing commands G92 R1 Z0.05 and G92 R1 Z-0.05 to test with. In the final release I hope to have the machine react faster to babystepping commands than it does in current alpha2 release.
                    jrlederer
                    Thanks for the prompt reply…gonna give it a try in the morning.
                    --Jonathan
                    • InSanityundefined
                      InSanity
                      Installed the new 1.2A motor for the Z-Axis up from the 450ma motor. Bed comp now works much more predictably. Running out of stuff that's original on the printer outside of the shell.
                      • mhackneyundefined
                        mhackney
                        David, a couple of quick babystep questions…
                        Are your macro files in the Git? or should I just create them myself?
                        Also, are you working with Christian to add buttons for the baby stepping right on the Print Status tab? That would be excellent.
                        My 3D Printing blog: http://www.sublimelayers.com
                        Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                        • Jackalundefined
                          Jackal
                          @mhackney I looked at the code and seems that G92 R1 Z#.## is all you need, so you can make the macro files yourself.
                            I haven't put the macros on github because they are one-liners. I have been discussing adding baby stepping buttons to DWC with chrishamm, and I will add them to PanelDue.
                            • iDeveloundefined
                              iDevelo
                              @dc42:
                              Nice. Just a simple up and down should do it.
