    Firmware 1.18 provisional change list
    Firmware wishlist
    13
    41
    6.7k
      Yes it's the firmware.
      • Simspeedundefined
        Simspeed
        Please keep in mind the 4 motor Z axis upgrade DC….thanks.
        Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
        • jrledererundefined
          jrlederer
          quick question for ya:
          just updated to latest beta 1.18 firmware, eager to test the baby-stepping feature. only thing is don't know how to adjust the newly added function. please advise.
          thanks, in advance, and hope everyone is having a nice day!!
          –jonathan
          "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
            Currently you send G92 R1 Z# where # is the amount you want to step in mm, in the range -1 to +1mm. I have created two macro files, containing commands G92 R1 Z0.05 and G92 R1 Z-0.05 to test with. In the final release I hope to have the machine react faster to babystepping commands than it does in current alpha2 release.
              jrlederer
              Thanks for the prompt reply…gonna give it a try in the morning.
              --Jonathan
              • InSanityundefined
                InSanity
                Installed the new 1.2A motor for the Z-Axis up from the 450ma motor. Bed comp now works much more predictably. Running out of stuff that's original on the printer outside of the shell.
                Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                • mhackneyundefined
                  mhackney
                  David, a couple of quick babystep questions…
                  Are your macro files in the Git? or should I just create them myself?
                  Also, are you working with Christian to add buttons for the baby stepping right on the Print Status tab? That would be excellent.
                  My 3D Printing blog: http://www.sublimelayers.com
                  Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                  • Jackalundefined
                    Jackal
                    @mhackney I looked at the code and seems that G92 R1 Z#.## is all you need, so you can make the macro files yourself.
                      I haven't put the macros on github because they are one-liners. I have been discussing adding baby stepping buttons to DWC with chrishamm, and I will add them to PanelDue.
                      • iDeveloundefined
                        iDevelo
                        @dc42:
                        Nice. Just a simple up and down should do it.
