    Duet Wifi 3 Z axis issue
    765
      droftarts administrators @sticks918
      @sticks918 What firmware version are you running? I assume RRF 3, but send M115 and post the response.
      I'm not sure I've seen a printer set up this way before; usually each individual Z motor has it's own driver, particularly when there are three motors. But I can't think of a reason that this wouldn't work. You won't be able to use the 'true bed levelling', as the two motors attached to the Z motor driver cannot work independently.
      The only problem with your config.g I can see is that you have defined each of the motor configuration lines with Z[nnn]:[nnn], eg M350 X16 Y16 Z16:16 E16 I1. The firmware will ignore the second value, and use only the first, but in some versions of the firmware this causes problems. Remove all the second Z values, eg:
      M350 X16 Y16 Z16 E16 I1                     ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z2560.00 E420.00   ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00      ; set maximum instantaneous speed changes (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00      ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30               ; set motor currents (mA) and motor idle factor in per cent
      If that doesn't help, configure just the E1 axis as Z, and test it, eg change M584 to:
      M584 X0 Y1 Z4 E3
      Try different motors if it continues not to work. It's also possible the E1 driver has failed.
      • sticks918undefined
        sticks918
        Thanks for the help Ian, here's what I've got:
        M115 response:
        FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-01-03b3
        I swapped the motors and cables with the two others and all motors have the same effect.
        I also tried your config and just had one Z axis motor on E1 using the config here:
        M569 P0 S1                                     ; physical drive 0 goes forwards
        M569 P1 S1                                     ; physical drive 1 goes forwards
        M569 P2 S1                                     ; physical drive 2 goes forwards
        M569 P3 S1                                     ; physical drive 3 goes forwards
        M584 X0 Y1 Z4 E3                               ; set drive mapping
        M92 X80.00 Y80.00 Z2560.00 E420.00             ; set steps per mm
        M84 S30                                        ; Set idle timeout
        But unfortuantely the same problem. Actually I tried running a motor from every driver by running through these M584 lines one at a time:
        M584 X4 Y1 Z0 E3                               ; set drive mapping
        M584 X0 Y4 Z1 E3                               ; set drive mapping
        M584 X0 Y1 Z3 E4                               ; set drive mapping
        And none of them worked correctly. E0, E1, and X drivers made the motor 'twitch' and using the Y driver made the motor hum like crazy until I resetted. Again, I tried this with multiple other working motors and cables and the motors have nothing on the drive shaft.
        So basically only the Z driver is spinning motors correctly. Any ideas? I feel like I'm stuck at step 0 here...
          sticks918
          Update:
          So I had one stepper motor from a different manufacturer laying around (a better quality e3d motor). When I plugged that in, it seems to work fine in any of the same configurations. Is there something in my config that would cause my original motors to only work from the Z driver, but a different motor (0.9 deg/step instead of 1.8) would work in any driver?
          I really would hate to have to buy 3 more motors...
          Thanks!
            @sticks918
            Add this line back in:
            M569 P4 S1                                     ; physical drive 4 goes forwards
            Otherwise, perhaps change the motor settings, particularly steps per mm on Z. I have dual Z on my printer, with only one motor attached to Z and E0. Here's my motor config, perhaps copy it and see if it works:
            M584 X0 Y1 Z2:3 E4                                 ; Set drive mapping
            M569 P1 S0                                         ; physical drive 1 goes backwards
            M569 P4 S0                                         ; physical drive 4 goes backwards
            M92 X80.00 Y80.00 Z800.00 E612.00                  ; set steps per mm
            M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
            M906 X1000 Y1000 Z800 E1000 I30                    ; set motor currents (mA) and motor idle factor in per cent
              sticks918
              Will do. Can you tell me if your Z motors are 0.9 or 1.8 deg / step? Thank you!
                @sticks918 1.8, but it shouldn’t matter for testing.
                • appjawsundefined
                  appjaws
                  If you have 3 Z motors, it is better to connect each one to a driver connection, then you can have 3 Z motor bed leveling.
                  Here is part of my config for my core XYUV machine
                  ;Drives
                  M584 X0:3 Y1:4 Z7:8:9 U10 V11 E2:5:6 ; Assign motors to axes
                  M569 P0 S1 ; Drive 0 goes forwards X motor
                  M569 P1 S1 ; Drive 1 goes backwards Y motor
                  M569 P2 S0 ; Drive 2 goes backwards E1 extruder
                  M569 P3 S1 ; Drive 3 goes forwards U motor
                  M569 P4 S1 ; Drive 4 goes backwards V motor
                  M569 P5 S0 ; Drive 5 goes backwards E2 extruder
                  M569 P6 S0 ; Drive 6 goes backwards E3 extruder
                  M569 P7 S1 ; Drive 7 goes forwards Z1 motor left
                  M569 P8 S1 ; Drive 8 goes forwards Z2 motor rear
                  M569 P9 S1 ; Drive 9 goes forwards Z3 motor right
                  M671 X-40:156:340 Y120:338:120 ; Lead screw positions
                  M350 X16 Y16 U16 V16 Z16 I1 ; Set XYUV 16 micro stepping with interpolation
                  Hope that helps
                  appjaws - Core XYUV Duet Ethernet Duex5
                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                  Ormerod 1-converted to laser engraver, Duet wifi
                  OpenSCAD version 2024.03.18
                  Simplify3D 5.1.2
                    droftarts administrators @appjaws
                    @appjaws True, but then you need a Duex! I guess he's trying it out before getting one, or going to add a single driver, perhaps like https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers#Section_Connecting_Pololu_style_drivers
                      sticks918
                      Appjaws and Ian are correct, I probably should be using a Duex but I wanted to get everything working as-is first and maybe upgrade to that later.
                      But for now I'm about running out of things to try, I played with just about every motor setting: steps / mm, speed change, acceleration, and motor currents and cannot get any of these 1.8 deg motors to work on any driver except Z.
                      The only other data point I can add is that if I boost the current (to say 2000 mA), the motor seems to move a bit closer to normal but I get a driver error saying there's a 'short-to-ground'. But only if it's above 1000 mA or so.
                      Any last suggestions guys? Right now it seems my options are to either go down to two Z axis motors or buy 3 new E3D motors. Neither of those seem like great options... Appreciate the help so far though.
                        sticks918
                        The only other thing I can think of is that for all the settings I was changing, I usually was lowering the setting (except for current). Would raising them help? Can you reach a point where you're driving the motor too slowly and it doesn't work properly?
                        • appjawsundefined
                          appjaws
                          I seem to remember in the distance past that I had motors integral with lead screws and they were twitching. I tried everything but could not get them to work. In the end I bought new motors and attached lead screws to them. They worked a treat, in fact I bought a third motor and changed my system to a 3 Z motor setup.
                          Have you tried your other motors, stand alone connected as Z?
                          these are my other motor settings.
                          M566 X1000 Y1000 U560 V560 Z60 E3000 ; Maximum jerk speeds mm/minute
                          M203 X12000 Y12000 U12000 V12000 Z100 E5000 ; Maximum speeds (mm/min)
                          M201 X1600 Y1600 U1000 V1000 Z30 E1500 ; Accelerations (mm/s^2)
                          M906 X1100 Y1100 U1100 V1100 Z1000 E950 ; Set motor currents (mA)
                          Simplify3D 5.1.2
                            @sticks918 I'm wondering if your motors are wired incorrectly. Is the only setup that works is two motors plugged into the Z drive? This might be possible due to the series wiring of the 2 Z motor connectors (I can't quite work it out in my head), but could be driving the Z in parallel. Please check the phases of one of the other motors. The motor pins on the Duet are ordered 2B 2A 1A 1B, so it expects one wire pair to be connected to 2B and 2A, and the other coil pair connected to 1A and 1B. Check which wires are the coil/phase pair using a multimeter, or see https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
                            I think the other thing to try is to define all motors as X, then Y, then Z, to see if it's a driver problem, a config problem, or a motor problem. ie try:
                            M584 X0:1:2:3:4
                            Try moving the X axis, then try
                            M584 Y0:1:2:3:4
                            and so on.
                            Make sure you run either M564 S0 H0 or G92 X0 Y0 Z0 each time you restart, or motors won't be able to move anyway!
                              sticks918
                              Hey guys,
                              I tired lowering and raising every setting under the sun but still no improvement. The only configuration that worked was 2 motors in series on the Z driver. Any single motor on any other driver did not work.
                              Since I need 3 of the same motor for Z, I switched them all out for E3D motors and they worked immediately. Shame I couldn't get my existing motors to work but that's okay. Thanks for the all the help though!
                              For anyone who stumbles across this, my motors were Tronxy sl42sth40-1684a-23 which are the standard issue from an upcycled Anet A8 (and probably other Anets).
                                @sticks918 I can't see anything on this page https://3dprint.wiki/reprap/anet/a8/steppermotor that would stop the stepper motor working with Duet. I think it's the wiring in the plug that connects to the Duet. Can you take a picture of the motor and plug wiring? Did you try and work out the motor phases?
