    Large Delta printer not homing on an original duet Maestro
    Example setups and prints
    2.5k
      dc42 administrators @NEVER LUCKY
      @NEVER-LUCKY said in Large Delta printer not homing on an original duet Maestro:
      when i press X, index 0 is Yes
      when Y, index 2 is Yes
      when Z, index 1 is yes
      does that mean that i have the X Y and Z wrong ?
      Looks like you have the Y and Z endstop wires swapped over.
      • NEVER LUCKYundefined
        NEVER LUCKY
        but does it really matter though? because when the endstop triggers for a particular axis, it only registers it for that one or not?
          It's vital that the X (index 0) endstop is on the same tower as the carriage that moves up 10mm when you send G91 G1 H2 X10. Likewise the Y (index 1) endstop must be on the same tower as the carriage that moves up when you send G1 H2 Y10; and similarly for index 3 and Z. Otherwise, when an endstop is triggered it will stop the wrong motor.
            NEVER LUCKY
            the red diag LED is lit, green blue and other red is also lit, but the board is not connecting to the web interface
              NEVER LUCKY
              i dont understand..... why is the board not responding on YAT ??? are these boards this fragile?
              • Danalundefined
                Danal @NEVER LUCKY
                The Duet series boards are extremely reliable. On the other hand, Windows USB support, to this day, is not totally reliable.
                Anyway... The most common cause for not being able to connect to the USB port is the cable. Try a different one.
                Also, when you plug/unplug the USB to the printer, does a serial port appear and disappear in Device Manager? Be sure that is the port that YAT is opening.
                  NEVER LUCKY
                  it isnt responding to my commands
                    Can you power it off, pull the SD card, and try again?
                      NEVER LUCKY
                      still nothing
                      • Danalundefined
                        Danal
                        Also... that shows 9600 baud. This should be 115200
                        Configure YAT as per: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7#s6
                          NEVER LUCKY
                          all i have is 2 red LEDs next to the usb port and a green and red LED lit, and no connection.
                          • Danalundefined
                            Danal @NEVER LUCKY
                            Again, it will not connect until:
                            1. You verify the port appears/disappears when you plug/unplug. Use device manager.
                            2. You configure it for LF line ends and more. See the link above.
                              Did something get shorted potentially during the rewiring of the endstops? Is all of the wiring still in place?
                              If following the YAT configuration linked above doesn't change anything, try disconnecting everything except USB. If that still doesn't work, connect the power supply for VIN as well.
                                NEVER LUCKY
                                the port appears and disappears in device manager.
                                it was already configured for LF.
                                after unplugging, still nothing.
                                after using VIN also nothing
                                  Just to remove YAT from the equation, can you try with pronterface? https://www.pronterface.com/
                                  The fact that it appears and disappears is a good sign. At least it's being detected by windows.
                                  The same windows USB stuff also applies. Try a different port. Reboot the PC. Try a USB hub.
                                    When you reboot the Duet, the port will disappear for a few moments and YAT will disconnect. So you may need to press Open/Connect button again. If that doesn't work, go to Settings in YAT and check that the port is still recognised. Restart YAT if you need to.
                                      NEVER LUCKY
                                      the port is perfectly fine, the board just doesnt reply to my messages, makes me sad 😞
                                      I installed pronterface and im not familiar with it at all
                                        Phaedrux Moderator @NEVER LUCKY
                                        There's a dropdown to select the USB port to connect to. You connect if possible and then you hopefully can send some commands from the console.
                                          NEVER LUCKY
                                          omg now it isnt online
                                          device manager shows the port as port 11
                                            What else shows in the port drop down?
