    Configure Laser Co2
    Laser Cutters
    1.0k
    • juanmenaundefined
      juanmena
      thanks for your reply
      Ye have modified LightBurn and the code comes out with the M3, as I had indicated. Send example.
      ; LightBurn 0.9.09
      ; Marlin device profile, absolute coords
      G21
      G90
      ; Scan @ 300 mm/sec, 20% power
      M05
      G0 X41.63 Y88.14 F0
      G91
      M03 S51
      G1 X-0.97 F18000
      M03 S0
      G1 X-4.26
      M03 S51
      G1 X-0.87
      M03 S0
      G1 X-4.11
      M03 S51
      G1 X-1.03
      M03 S0
      G1 X-0.33 Y-0.1
      M03 S51
      G1 X1.69
      M03 S0
      G1 X3.46
      M03 S51
      G1 X1.49
      M03 S0
      G1 X0.88
      M03 S51
      G1 X0.76
      M03 S0
      G1 X2
      M03 S51
      G1 X1.68
      M03 S0
      G1 X1.17
      M03 S51
      G1 X0.89
      M03 S0
      G1 X1.11
      M03 S51
      G1 X0.87
      M03 S0
      My question now is ... to fire the laser, I have the PWM of the fan controlling the (IN) Imput 0-5 V.
      What output do I have to connect to TH of the laser power supply ??? GND H2 ??? or positive + H2 ???
      Thank you.
      P.D .: Sending photo connection of the power supply
      alt text)
      https://ibb.co/XDZ35BC
      https://ibb.co/N298VYH
        Marlin doesn't understand G1 commands with S1 parameter, so it is not an appropriate profile to use.
        juanmenaundefined 1 Reply Last reply Reply Quote 0
        • juanmenaundefined
          juanmena @dc42
          @dc42 Very funny and sorry that I have to bother again, but something I do not understand.
          You are not sending the G1 command with parameter S1. Or I did not understand something.
          I send a piece of a Gcodec, to tell me where the error is, by using the M3 command with the S1 parameter that Gcodec, or do I have to modify something in the config.g ????
          • juanmenaundefined
            juanmena
            I keep looking, but I don't see the error it refers to.
            Any help please?
            Thank you
              If LightBurn doesn't have a device profile for RepRapFirmware, try a profile for Smoothieware. That should generate G1 commands with S parameters to set the laser power.
              • juanmenaundefined
                juanmena
                I tried Ligtbrurn with the Smoothieware profile and generated the Gcodec that I put next. Is this seriously correct? Can something better be done to get more performance when recording with the Duet with other software?
                ; LightBurn 0.9.09
                ; Smoothieware device profile, absolute coords
                G00 G17 G40 G21 G54
                G90
                M3
                M106
                G0X115.81Y96.3
                G91
                G1X-4.62F18000S51
                G1X-0.05Y-0.1S0
                G1X4.72S51
                G1X0.06Y-0.1S0
                G1X-4.84S51
                G1X-0.06Y-0.1S0
                G1X4.96S51
                G1X0.06Y-0.1S0
                G1X-5.08S51
                G1X-0.05Y-0.1S0
                G1X5.18S51
                G1X0.06Y-0.1S0
                G1X-5.3S51
                G1X-0.06Y-0.1S0
                G1X5.42S51
                G1X0.06Y-0.1S0
                G1X-5.54S51
                G1X-0.06Y-0.1S0
                G1X5.66S51
                G1X0.05Y-0.1S0
                G1X-5.76S51
                G1X-0.06Y-0.1S0
                G1X5.88S51
                Thank you
                  That's much closer to ideal. The laser is being controlled by S parameters on the G1 commands. Some of the commands at the start are odd (e.g. M106 with no parameters), but harmless.
                  What issue do you have with performance?
                  • juanmenaundefined
                    juanmena
                    We are a group in Spain of more than 20 people, we have mounted a CO2 laser and mine, is the first that is working. We have installed Duet2D Maestro and we are looking for a software that generates a Gcodec completely compatible with Duet and the Laser.
                    We have acquired some already LightBurn, but we are not having good results, we do not know if the culprit is the adjustment of the Duet or it is of the Software, since with a Laser K40 and plate of very little quality, it was obtaining better results with K40 Wisperer.
                    Maybe we have to make some adjustments or change the software.
                    https://photos.app.goo.gl/gz8XiZ7GXHnrQg7h6
                    https://photos.app.goo.gl/KrJzu9yycSjMEtMf6
                    Could you make some recommendations?
                    Thank you very much.
                    P.S.: Sorry, but I don't know English and I use Google translator.
                    • EasyTargetundefined
                      EasyTarget
                      @juanmena
                      You might want to read this thread: https://forum.duet3d.com/topic/12150/laser-gcode-s-sticky-after-g0-question, there is some discussion of how to configure LightBurn with Duet/RRF Firmware. The bad news is that there is no built in 'compatibility' for the Duet in LightBurn.
                      Currently I use LaserWeb; (but I control a Grbl CNC, not Duet, so cannot give a config).
                      https://github.com/LaserWeb/LaserWeb4
                      LaserWeb is very good at preparing raster and dither images from bitmaps and jpeg's etc. And at cutting and filling svg (vector) images. But it has no image editing tools beyond resizing and rotating them. So I often use Pinta or InkScape to prepare the source material first.
                      LaserWeb can run as a standalone application on your laptop/pc to generate Gcode and optionally control/stream to the firmware via USB or telnet if desired. Look for the windows 'electron' build.But I use it it on a Raspberry PI in web client/server mode to give myself a webUI.
                      Since you can configure all headers etc with laserweb it is much easier than LightBurn to configure for a Duet. The inbuilt RRF profile is a good start.
                      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
                      PrintPy2024 to the rescue!
                      MicroPython based; with simple wiring and and no custom PCB.
                      • juanmenaundefined
                        juanmena
                        @EASYTARGET Thanks for answering.
                        I've been installing and testing and that's why I've been slow to answer.
                        LaserWeb, generates a Gcode without the G1 in front of each line and the Duet, does not respond to these movements. For the rest, it seems that it could be worth it, but without that, it does not move in conditions. Step example of what it generates ...
                        G1 X2.15 Y2.15 S0.0000
                        X21.95 S0.3129
                        Y2.45 S0.0000
                        X21.80 S0.6872
                        X2.30 S0.7000
                        X2.15 S0.4841
                        Y2.75 S0.0000
                        Those lines are not valid for Duet.
                        Let's see if someone can help me, because I think I'm going to have to leave Duet for the Laser.
                        • juanmenaundefined
                          juanmena
                          Good morning,
                          First of all I want to thank all the help I'm getting, but it's not working for me, I think the installation is correct, and I apologize for what could bother me with so many questions, but I would not like to leave the project.
                          I will explain my approach and the duas.
                          The first thing is to check the installation I have is the correct one, or I would have to change to option 2 or some other cable. The PWM always goes through a converter board
                          My installation (Duet - Laser power supply)
                          FAN0 - FAN0- <> Signal Ground GND
                          FAN0 - V_FAN_A <> Imput Control Signal (0-5V)
                          E1 HEATER - E1- <> Switch Laser Control (Active Low)
                          I am asking if option 2 would be more correct, connect E1 HEATER - E1- <> Imput Control Signal (0-5V)?? and activate "Switch Laser Control (Active low) with another PIN that acts directly on/off with M3/M5?
                          I pass photos:
                          E1 may be doing PWM by the Switch Laser Control (Active Low) PIN
                          from the laser power source?
                          Is this Gcode format correct?
                          ; LightBurn 0.9.09
                          G00 G17 G40 G21 G54
                          G90
                          M3
                          M106
                          G0X115.81Y96.3
                          G91
                          G1X-4.62F18000S51
                          G1X-0.05Y-0.1S0
                          G1X4.72S51
                          G1X0.06Y-0.1S0
                          I've been looking at this post, but I think it was talking about K40 and yet I think this laser power supply, could it be connected differently or am I on the wrong track?
                          Thank you very much again
                            dc42 administrators @juanmena
                            @juanmena said in Configure Laser Co2:
                            X21.95 S0.3129
                            Y2.45 S0.0000
                            X21.80 S0.6872
                            X2.30 S0.7000
                            X2.15 S0.4841
                            Y2.75 S0.0000
                            Currently, RRF recognises that style of command in CNC mode but not in Laser mode or FFF mode. I will change it in RRF 3.01RC2 to recognise those commands in Laser mode too.
