    Problems with XY Homing
    Firmware installation
    homing
    438
    • MauriceMundefined
      MauriceM
      Good Morning,i have Problems to home my X and Y axis. The LED on the board is not on, but the board thinks the endstop is triggered.
      So if i want to home e.g X the carriage will move some mm to one side and than says that it is homed. But when i close the endstop and home X, the printer wants to home untill i release the endstop.
      I tried all Possible configuration and i dont now what im doing wrong.
      I have 2 phases Endstops, i dont now if they are NO ore NC. I trief both configuration but nothing worked.
      H had the same problem with the Z axis until i added I1 in config.g for Z Probe, but that didnt worked for the other axis.
      Config.g:
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Tue Feb 11 2020 10:36:53 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Anet E12" ; set printer name
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M906 X950 Y950 Z950 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X310 Y310 Z400 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop
      M558 P5 C"zprobe.in+zprobe.mod" H5 F120 T6000 I1 ; set Z probe type to switch and the dive height + speeds
      G31 P500 X25 Y25 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:290 Y15:290 S20 ; define mesh grid
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      deckingmanundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        deckingman @MauriceM
        @MauriceM I sounds like you need to invert the input. It also looks like you using RRF3 so the "I" parameter won't work. Instead you need to put "!" before the pin name. So M574 X1 S1 P"!xstop" instead of M574 X1 S1 P"xstop"
        • SIamundefined
          SIam
          @MauriceM said in Problems with XY Homing:
          try to invert your endstops with:
          M574 X1 S1 P"!xstop" ; configure active-low endstop for low end on X via pin xstop
          M574 Y1 S1 P"!ystop" ; configure active-low endstop for low end on Y via pin ystop
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
          • MauriceMundefined
            MauriceM
            Thanks, it workes flawless. now i have to change the motor to the right direction and it will work.
            But why did the I1 on the Z Probe worked? bevor that change the z probe was also triggered the whole time.
              dc42 administrators @MauriceM
              Currently, the I parameter on the M558 command is still supported, but it will probably be removed in a future firmware version.
              • SIamundefined
                SIam
                it seems that this is not removed in rrf3 if you want to make it right then add ! and remove I1 to this line
                M558 P5 C"!zprobe.in+zprobe.mod" H5 F120 T6000  ; set Z probe type to switch and the dive height + speeds
                • MauriceMundefined
                  MauriceM
                  Ah ok, i will change it. Thanks
                    droftarts administrators @MauriceM
                    If you're using the Z probe for homing Z, and have no endstop, this should be M574 Z0.
                    • MauriceMundefined
                      MauriceM
                      but its working so i dont have to change it or will it cause problems?
                        @MauriceM It's fine to leave it if you home Z using G30. But if, by mistake, you try using (or your homing.g files contain) a G1 H1 (ie a homing move) on Z, it will try to use the non-existant endstop, rather than the probe, to home Z, resulting in a crash. Better to remove the chance!
