Reinstall firmware on duet3, now no flashing led
That message is generated when the firmware can find none of index.html, index.html.gz, reprap.htm amnd reprap.htm.gz in /www. As you have index.html.gz (which is the correct file for DWC 2.x) in /www, it should work.
Bear in mind that after removing the SD card and reinserting it into the Duet, you need to re-mount the card either by sending M21 or by rebooting the Duet.
@Danal M552 says enabled and shows my ip address
@chichirod said in Reinstall firmware on duet3, now no flashing led:
Good. Then the network is OK and we can chase web stuff only.
Still getting "page not found"?
As dc42 said, the very opening page is hardcoded to one of those four names, in /www
@dc42 ok I have never done the m21 but I have rebooted it and then made sure that yat could read the card and that it was showing up in my router
@Danal I will try giving this a go, give me a few minutes and ill let you know how it worked.
ok in taking a closer look I do have all or most of those files anyway
but you have them in the wrong places; where i had d:\www you have g:\config\sys\www thats not going to work, and it clearly doesn't
Good catch @bearer , they are indeed in the wrong places.
In particular, /sys and /www must be in the 'root' of the SD card. No directories 'above' them.
My SD card shows up as F:. Note there is nothing else in the path (top red circle)
The two most important directories are 'sys' and 'www'. The system will create all the others when it is up and running.
Therefore, @chichirod , you can build a fresh card as I outlined a few posts above... OR... just drag the folders on the card you have to the right places. Either way should work.
I tried what you said with the fresh SD card, downloaded the file and unzipped it onto the card. I think it looks right. However still not showing up on desk top
Its still in g:\config\www
or maybe a visual representation helps.
open two windows side by side. select the files and drag them across
@bearer
ok I think NOW its correct
@bearer said in Reinstall firmware on duet3, now no flashing led:
yes, now you just have to go back to that link and download the latest release if it still gives you problems.
Get 'config' as a directory out of your head. No such directory exists, anywhere, in the way the card should be setup.
And, yes, we are probably past the above as your latest screenshot looks great!!
@bearer sorry still a no go
@Danal said in Reinstall firmware on duet3, now no flashing led:
just realized it could be something like this
but still instructions are clear enough not to do something like that.
@chichirod please read https://support.microsoft.com/en-us/help/13776/windows-10-use-snipping-tool-to-capture-screenshots (or watch https://www.youtube.com/watch?v=O_55eg00H-w )
and then run
M20 P"/www"
in the terminal. -
@chichirod well, unless that command shows you something like
css favicon.ico.gz fonts index.html.gz js
its not going to work. and please try to make use of the snipping tool to avoid pasting a huge picture of whiteness. or even better copy the text and paste it in markdown formatting.
