Reinstall firmware on duet3, now no flashing led
Good catch @bearer , they are indeed in the wrong places.
In particular, /sys and /www must be in the 'root' of the SD card. No directories 'above' them.
My SD card shows up as F:. Note there is nothing else in the path (top red circle)
The two most important directories are 'sys' and 'www'. The system will create all the others when it is up and running.
Therefore, @chichirod , you can build a fresh card as I outlined a few posts above... OR... just drag the folders on the card you have to the right places. Either way should work.
I tried what you said with the fresh SD card, downloaded the file and unzipped it onto the card. I think it looks right. However still not showing up on desk top
Its still in g:\config\www
or maybe a visual representation helps.
open two windows side by side. select the files and drag them across
@bearer
ok I think NOW its correct
@bearer said in Reinstall firmware on duet3, now no flashing led:
yes, now you just have to go back to that link and download the latest release if it still gives you problems.
Get 'config' as a directory out of your head. No such directory exists, anywhere, in the way the card should be setup.
And, yes, we are probably past the above as your latest screenshot looks great!!
@bearer sorry still a no go
@Danal said in Reinstall firmware on duet3, now no flashing led:
just realized it could be something like this
but still instructions are clear enough not to do something like that.
@chichirod please read https://support.microsoft.com/en-us/help/13776/windows-10-use-snipping-tool-to-capture-screenshots (or watch https://www.youtube.com/watch?v=O_55eg00H-w )
and then run
M20 P"/www"
in the terminal. -
@chichirod well, unless that command shows you something like
css favicon.ico.gz fonts index.html.gz js
its not going to work. and please try to make use of the snipping tool to avoid pasting a huge picture of whiteness. or even better copy the text and paste it in markdown formatting.
@bearer yeah sorry about that
is that with the files from
https://github.com/T3P3/Duet/blob/master/Duet2/SD Card Contents/SD_Card_Contents.zip
or did you try going back to to get the latest version?
@bearer i tried running m122 and I got this, sorry I know its hard to read in this format but I made a spot bold. Its saying ethernet blocked
=== Diagnostics ===<LF>RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.0 running on Duet 3 MB6HC<LF>Board ID: 08DJM-956L2-G43S8-6JKDD-3SS6L-TB12H<LF>Used output buffers: 1 of 32 (2 max)<LF>=== RTOS ===<LF>Static ram: 152720<LF>Dynamic ram: 148504 of which 0 recycled<LF>Exception stack ram used: 384<LF>Never used ram: 91608<LF>Tasks: ETHERNET(blocked,456) NETWORK(ready,460) HEAT(blocked,1416) CanReceiv(suspended,3808) CanSender(suspended,1476) CanClock(blocked,1412) TMC(blocked,212) MAIN(running,4220) IDLE(ready,160)<LF>Owned mutexes:<LF>=== Platform ===<LF>Last reset 00:25:35 ago, cause: reset button<LF>Last software reset details not available<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 25.0MBytes/sec<LF>SD card longest block write time: 0.0ms, max retries 0<LF>MCU temperature: min 27.8, current 32.3, max 32.6<LF>Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes<LF>12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage event[Warning: Maximal number of bytes per line exceeded! Check the EOL (end-of-line) settings or increase the limit in the advanced terminal settings.]
@bearer i went back to get the latest version
as long as you\re getting the http404 error saying to put the files in /www and M20 shows no files in /www that is where the problem is no matter where you go looking for other ansewrs.
What @bearer said. The www directory must have the correct files.
With the SD card in your PC, copy/paste the following into the address bar of file explorer, then hit enter:
cmd /c "tree /F /A > tmp.txt"
This will cause a file named 'tmp.txt' to appear on the SD card. Double click on it, so it opens in notepad.
The directories and files MUST look like this (I may have more files in 'sys' than you do. 'www' must look EXACTLY like this, with the number codes like '40fc83ce' possible being different ) :
Folder PATH listing Volume serial number is 2CA4-0623 F:. | README.txt | tmp.txt | +---sys | bed.g | cancel.g | config.g | iap4s.bin | homedelta.g | heightmap.csv | pause.g | resume.g | sleep.g | stop.g | tfree0.g | tpost0.g | tpre0.g | Duet2CombinedFirmware.bin | DuetMaestroFirmware.bin | DuetWiFiServer.bin | dwc2settings.json | iap.bin | iap4e.bin | DuetWiFiFirmware.bin | +---www | | favicon.ico.gz | | html404.htm | | language.xml.gz | | reprap.htm.gz | | Multi.htm.gz | | language.xml | | dwc.json | | index.html.gz | | | +---css | | bootstrap-theme.css.gz | | dwc.css.gz | | slate.css.gz | | Dark.theme.css.gz | | bootstrap.theme.css.gz | | United.theme.css.gz | | Superhero.theme.css.gz | | Lumen.theme.css.gz | | Sandstone.theme.css.gz | | Slate.theme.css.gz | | app.17f89ff3.css.gz | | chunk-vendors.30c0b939.css.gz | | app.c08121ce.js.map.gz | | chunk-vendors.92cfeab5.js.map.gz | | app.40fc83ce.css.gz | | app.eb4376bc.css.gz | | | +---fonts | | glyphicons.eot.gz | | glyphicons.svg.gz | | glyphicons.ttf.gz | | glyphicons.woff.gz | | glyphicons.woff2.gz | | Homenaje-Regular.ttf.gz | | MaterialIcons-Regular.570eb838.woff2 | | MaterialIcons-Regular.012cf6a1.woff | | MaterialIcons-Regular.a37b0c01.ttf.gz | | MaterialIcons-Regular.e79bfd88.eot.gz | | MaterialIcons-Regular.bca3a187.woff2 | | MaterialIcons-Regular.9219a80f.woff | | MaterialIcons-Regular.586090b3.ttf.gz | | materialdesignicons-webfont.4c3075c9.woff2 | | materialdesignicons-webfont.88ffecaf.woff | | materialdesignicons-webfont.c7a79340.eot.gz | | materialdesignicons-webfont.2abd86f9.ttf.gz | | | +---js | | MultiDWMC.js.gz | | app.c08121ce.js.gz | | app.296c62fd.js.gz | | dwc.js.gz | | chunk-vendors.92cfeab5.js.gz | | app.296c62fd.js.map.gz | | app.2a4070cd.js.gz | | app.2a4070cd.js.map.gz | | (I cut mine off, because I have some extra stuff.)
