duet connection
Duet Web Control
740
    A Former User
    Try M20 to confirm the Duet sees the files in the correct location , or check that the card doesn't have multiple partitions (although the card showing as 32g would suggest it may not be partitioned) (if the card works in a different printer it would more so suggest issues with the duet and sd card socket. maybe see if you can get a good macro picture of the solder joints on the sd card socket)
    undefined 1 Reply Last reply 19 Feb 2020, 05:43 Reply Quote 0
      tdybare69 @A Former User
      @bearer i think thts it . be right back gonna make sure there is no partitions. it says files none.
      undefined 1 Reply Last reply 19 Feb 2020, 06:03 Reply Quote 0
        tdybare69 @tdybare69
        @tdybare69 i think your right. something has to be wrong with board.everything i try it still says none.
        undefined 1 Reply Last reply 19 Feb 2020, 06:04 Reply Quote 0
          @tdybare69 its new board. but i have had it for a while in box, stored safely. got it from matter hackers.
          undefined 1 Reply Last reply 19 Feb 2020, 20:34 Reply Quote 0
            A Former User
            Hmm, still odd it mounts the card gets the capacity correct (assuming the capacity is shown correctly?) Confirm the capacity and see what you can do about a picture.
            In any case I'm sure your friendly neighborhood administrator @dc42 will be along shortly with some insight.
              dc42 administrators @tdybare69
              @tdybare69 said in duet connection:
              @bearer i went to github got the files you said,extracted it,and tried again. still says same thing. did M21 it says SDHC card mounted in slot 0, capacity 31.9GB<LF>ok<LF>
              M39 says SDcard in slot 0: capacity 31.9GB, speed20.00MBytes/sec,cluster size 167kb<LF>ok<LF>
              Are you sure it says cluster size 167kb? That's not right.
                A Former User
                But if the card works in another Duet the cluster size has to be OK, as well as the files present on the card?
                Except its not, with two different cards.
                  droftarts administrators @tdybare69
                  @tdybare69 can you take a close up picture of the pins on the end of the SD card socket? I suspect poor soldering.
                  undefined 1 Reply Last reply 20 Feb 2020, 05:13 Reply Quote 0
                    tdybare69 @droftarts
                    @droftarts finally got it to work. took sd card from working duet printer. ran a M21&M39, went to working.
                      A Former User
                      Isn't that exactly the same you said didn't work yesterday?
                      undefined 1 Reply Last reply 20 Feb 2020, 16:10 Reply Quote 0
                        @bearer yes. maybe the board had to warm up. got me stumped. i have come across weirder things than that unfortunately.
                        15 out of 16
