Modix Big120X Upgrade
    iff7378
    I've got one of these gigantic printers with a RAMPS controller. I'm considering upgrading the whole control system to the Duet 3. Modix just released a version 3 of their printer with a Duet 2 but I figured why not go right to the Duet 3. The whole reason for this is to be able to use the magnetic filament monitors. Its no fun when a 24 hour print fails in the last hours because the filament jammed.
    I want to make sure all of this will work before I order a ton of stuff.
    With the Duet 3 and a raspberry Pi, I would just run a touchscreen off the Pi's HDMI port and not use a PanelDue right?
    Right now I think the setup is:
    Duet3:
    X Y Z Steppers
    Output to heated bed SSR
    Bed temp sensor
    CAN bus to Tool Distribution to two toolboards
    Toolboard 1 has:
    • Extruder Stepper 1
    • Heater 1
    • Fan 1
    • Filament Monitor 1
    • BLTouch
    • Nozzle Blower Fan
    Toolboard 2 has:
    • Extruder Stepper 2
    • Heater 2
    • Fan 2
    • Filament Monitor 2
    Any feedback on the setup would be appreciated!
      That all sounds good, except that the firmware support for filament monitors connected to tool boards or Duet 3 expansion boards isn't written yet. It's planned for the RRF 3.02 release.
        iff7378
        Awesome thanks! Any idea when that release is planned to happen?
        Edit: Is it possible to directly connect the monitors to the Duet 3 mainboard with the current firmware?
        undefined 1 Reply Last reply 21 Feb 2020, 20:46 Reply Quote 0
          dc42 administrators @iff7378
          @iff7378 said in Modix Big120X Upgrade:
          Release 3.01 should be out by the end of this month. 3.02 will most likely arrive late March or late April.
          Yes.
          2 out of 4
