    Grid bed compensation
    Firmware wishlist
    23
    100
    19.6k
    • Phytone3dundefined
      Phytone3d
      and here is the bed file, of another run:
      RepRapFirmware height map file v1, mean error -0.68, deviation 0.24
      xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
      40.00,240.00,20.00,220.00,-1.00,20.00,11,11
      -0.209, -0.239, -0.680, -0.433, -0.411, -0.539, -0.924, -0.377, -0.448, -0.751, -1.148
      -0.263, -0.801, -0.364, -0.404, -0.672, -0.803, -0.520, -0.655, -1.017, -0.631, -0.571
      -0.286, -0.202, -0.485, -0.892, -0.488, -0.396, -0.830, -0.675, -0.552, -0.616, -1.123
      -0.522, -0.810, -0.453, -0.478, -0.921, -0.594, -0.517, -0.916, -1.042, -0.658, -0.584
      -0.421, -0.510, -0.988, -0.500, -0.379, -0.751, -0.860, -0.744, -0.505, -0.990, -0.707
      -0.549, -0.470, -0.658, -1.057, -0.542, -0.473, -0.776, -0.892, -0.621, -0.562, -1.025
      -0.995, -0.537, -0.493, -0.722, -0.990, -0.648, -0.633, -0.941, -0.722, -0.522, -0.719
      -0.946, -0.717, -0.534, -0.768, -1.101, -0.643, -0.547, -0.648, -0.968, -0.539, -0.547
      -1.020, -0.739, -0.616, -0.685, -1.163, -0.589, -0.429, -0.732, -0.985, -0.534, -0.451
      -1.148, -0.685, -0.574, -0.756, -1.081, -0.677, -0.490, -1.429, -0.921, -0.601, -0.547
      -0.906, -0.670, -0.677, -1.096, -0.628, -0.485, -0.751, -1.076, -0.525, -0.389, -0.732
        deckingman
        On DC42s blog write up https://miscsolutions.wordpress.com/mini-height-sensor-board/, he talks about bed surfaces and states " Bright aluminium: not suitable unless the sensor is modified to reduce its sensitivity, because the strong reflection will saturate the sensor." You state that you are probing straight onto the top of the aluminium tooling plate so maybe that's where things are going a bit haywire. Maybe paint the plate matt black? - I use stove paint and bake it in the oven. HTH
          Phytone3d
          I get a similar trace when doing it on printbite, which is why I got some new plate. I'll find some black card and insert between the printbite and plate to see if that helps first.
          Thanks for the tip.
            deckingman
            @Phytone3d:
            Thanks for the tip.
            DC does recommend painting the plate black if you are using glass. I know printbite isn't glass but it's still fairly transparent so maybe the same applies? Black card has to be worth a try. Stove paint is a bit expensive so I can understand that you'd want to be sure it will work. Ian
              Phytone3d
              Couldn't find any card, so thought running the grid probe in the dark….
              Amazes me it works, but oh well... ordered some paint, for sake of £7, has to be worth a try.....
              • DjDemonDundefined
                DjDemonD
                It does seem unlikely that your tooling plate is that uneven. So its either mechanical play or a sensor issue. I found the IR sensor to be quite good with printbite, no real issues with it. However perhaps try a contact sensor like the piezo system and see the difference.
                This is what you want to see
                I'm using 6mm tooling plate and printbite with a piezo hotend probe.
                www.precisionpiezo.co.uk
                  Phytone3d
                  I'm fairly sure there is no mechanical play, it's a metal v-slot build. May play with probing speeds and sensor drop height to see if that has any impact (2mm at moment). Paint should be here soon - but there is no way that the probe heightmap correlates to the actual bed.
                  I'd love to try a piezo, but no piezo/control board and need to think how to mount in a titan extruder.
                  Is there a way to desensitise dc's IR Probe?
                  • DjDemonDundefined
                    DjDemonD
                    You can change the threshold value in G31 Px where x is the threshold from 0-1000 default 500.
                    Whether this will really smooth it out or just change the height at which it triggers by a few microns, I do not know.
                      The IR probe should always be used with a trigger threshold of 500, because it only outputs 4 different values - about 0, 465, 535 and 1000.
                      I think what you are seeing is variation in trigger height caused by reflections from behind the glass. A sheet of black or other dark paper between the glass and the bed plate will substantially reduce the variation. I have used all of the following:
                      • Painting the aluminium bed plate black with heat-resistance paint, cured in an oven
                      • Black paper (found in the art supplied department of a stationery shop) between the bed heater and the glass
                      • Printing an A4 sheet of paper all black (except the margins) and putting it under the glass
                      • Spraying the back of the transparent surface black and curing the paint in an oven (I haven't tried this with glass, but it worked well for me with PEI).
                        Phytone3d
                        Well, I've ordered a board from Idris and piezo's from Ebay, so will have a play, once I figure out a suitable mount for a Titan extruder.
                          Phytone3d
                          @dc42:
                          Thanks David. I don't use glass. The readings are the same with both PrintBite and on new cast tooling plate (with the protective film still on). I have some paint coming, so will certainly try that, whilst having a look at this piezo method. I'm sure it must be something simple.
                          On my old RAMPS, i just probed the four corners and it worked (this is a cartesian printer), and there was a very minimal difference across the first printed layer for irregularities, and I suppose I could go back to 4 corners - but now, I have seen this weird height map, I want to fix it.
                            @Phytone3d:
                            Do you ever get a reading of about 1000 from the Z probe? That's possible if you are using a highly-reflective surface such as bare aluminium, especially with the older version 1.1 sensors. That reading indicates that the sensor is saturated, which would explain the height map you are getting. You might want to try resting a sheet of ordinary white paper on top of the tooling plate, and probing against that.
                            • c310undefined
                              c310
                              i have put M557 R85 S20
                              in my bed.g but when i try G29 it gives an error
                              Error: No valid grid defined for G29 bed probing
                              please advise how to fix it. thanks!
                                Try sending that M557 command from the console and see what error message you get, and/or send M557 with no parameters to see what grid is in effect.
                                • c310undefined
                                  c310
                                  M557 from console : Grid is not defined
                                  if i manualy enter M557 R90 S20 from console than G29 works fine
                                    The M557 command should normally be put in config.g not in bed.g. If you put in in bed.g then the grid won't be defined until you run G32.
