Enable endstops on a Duex5
3.6k
    Loffy770
    I have Duet WiFi and a Duex5. Now I have connected Sunex GL 8 endstops to 5v on Duex and it looks to be working ok, they light up so some reaction is in there. But how do I assign them to my XYZ.. cant find any info on that..
    Thanks
    Roger
      Currently there isn't a faciliary to reassign endstop connections. This is on the firmware wish list.
        Loffy770
        Ohh, can I use the drivers on Duex as XYZ and get around the problem in that way?
          Loffy770
          Okay, I have pulled 5v from Duex5 and moved the signal to Duet, it lights up but there is no reaction when doing a home… The way I tested it was by doing a safe distance Z home and then putting a screw driver on the sensor. It lights up but does not stop the Z from moving...
          Am I missing something?
            iDevelo
            @Loffy770:
            What commands are you using to home Z?
              Loffy770
              Just the home buttons on the web interface and or Paneldue.
                @Loffy770:
                Sorry, mapping drivers does not map endstops.
                  Loffy770
                  So how can I get past this.. whats the workaround?
                    @Loffy770:
                    Use M119 or the Settings->Machine Properties tab of DWC to test the endstops.
                    Can you post a link to the datasheet of the endstops, and tell us how you have connected them to the Duet? Does the endstop LEDs on the Duet show the correct endstop state?
                      Loffy770
                      I took voltage from Duex endstop + & - then I took signal from Duet endstop Z.
                      When Z is moving I get a led from Sunx when I put a screwdriver on it on Duet Zendstop the led comes on with red light. Z continues to move though.
                      Sunx link http://www.clrwtr.com/PDF/SUNX/SUNX-GL-8U-Proximity-Sensors.pdf
                      With m119 I get a popup
                      Endstops - X at min stop. Y at min stop. Z at min stop. Z probe not stopped.
                        Loffy770
                        These end stops are rated 12-24 but works with 5v as they are originals in my printer and runs well with 5 v.
                          Loffy770
                          any ideas? Some more to test?
                            Which particular model of the GL8 series are they?
                              Loffy770
                              Its a Gl8h top sensing 3 wire model "normally open"
                                Have you set up your M574 command and your homez.g and homeall.g files to tell the firmware that you are using an endstop for Z homing? See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Cartesian_printer. Your files may be set up for Z homing using a Z probe instead, depending on where they came from.
                                  Loffy770
                                  Well I used the configurator to set it but I will go through it again.
                                  Just to be on the safe side.. I connected black signal cable to the outer pin closest to usb port on Duet. Looking at schematics for Duet it looks like it should be the other way around.. but if I do that I get no led light on Duet.
                                  On Duet I have + brown cable and - blue cable.
                                    Loffy770
                                    Can confirm the wrong in the schematics now, just measured it and power is wrong in the Duet schematic.
                                      Loffy770
                                      I have M574 X1 Y1 Z1 S0
                                      Had a M558 line active and put a rem in the front now, is that correct to rem that line and use the above for open and low homing?
                                      If so I will test this now.
                                        Loffy770
                                        Configuration file for Duet WiFi (firmware version 1.17)
                                        ; generated by RepRapFirmware Configuration Tool on Sat Mar 04 2017 15:46:00 GMT+0100 (W. Europe Standard Time)
                                        M111 S0 ; Debugging off
                                        G21 ; Work in millimetres
                                        G90 ; Send absolute coordinates…
                                        M555 P2 ; Set firmware compatibility to look like Marlin
                                        M208 X370 Y250 Z280 S0 ; Set axis maxima
                                        M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
                                        ;M558 P1 X1 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
                                        G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                        M557 X15:215 Y15:195 S20 ; Define mesh grid
                                        M569 P1 S0 ; Drive 1 goes forwards
                                        M569 P2 S0 ; Drive 2 goes forwards
                                        M92 X80 Y81 Z390 E189 ; Set steps per mm
                                        M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                                        M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                                        M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                                        M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                                        M84 S30 ; Set idle timeout
                                        M143 S285 ; Set maximum heater temperature to 260C
                                        M305 P0 T130600 B6084 C2.635903e-7 R4700 ; Set thermistor + ADC parameters for heater 0
                                        M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                                        M307 H0 P130.1, I0.213, D449.1
                                        M563 P0 D0 H1 ; Define tool 0
                                        M550 Black Widow ; Set machine name
                                        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
                                        M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                                        M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                        M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                                          Loffy770
                                          Okay I have X homing as it should!
                                          Y is homing in the wrong direction even though I did set it to low. Tried o change it to high incase there was a bug or something but it didnt work… It however stops if I put a screwdriver on the sensor so the sensor is communicating to the board correctly.. Its just the motor homing in the wrong direction despite being configurated as below.
                                          ;M558 P2 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to modulated, the axes for which it is used and the probe + travel speeds
                                          ;G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                          ;M557 X15:355 Y15:235 S20 ; Define mesh grid
                                          Z does not stop with any metal on it but it still lights up on the board.
                                          Firmware Name: RepRapFirmware for Duet WiFi
                                          Firmware Electronics: Duet WiFi 1.0 + DueX5
                                          Firmware Version: 1.17c (2017-01-14)
                                          WiFi Server Version: 1.03 (ch fork)
                                          Web Interface Version: 1.14a
                                          2 out of 32
