    Motor don't turn at direction change
    520
    • Danalundefined
      Danal @Bipotronic
      @Philipp-R said in Motor don't turn at direction change:
      14rev/sec to print at a speed of 40mm/s.
      I also don't get that.
      1911 Steps per mm. (approx)
      400 steps to turn a 0.9 motor one full rev.
      400/1911 = .2 mm per rev (approx)
      14 rev sec * .2 mm per rev would mean you are going to extrude 2.8 mm of filament from the extruder in one second, while X and Y move 40mm.
      I just checked some slicer output and I'm seeing just a tiny bit over 1 mm of output across 40mm of movement. Your calculations seem about 2.5 to 3x too much.
      Are you using a very large nozzle? Something else that generates this much filament?
      Bipotronicundefined 1 Reply Last reply Reply Quote 0
      • Danalundefined
        Danal
        Per a statement by DC42 several months back, Extruders only use accel and jerk when they reverse. They do not use these numbers when 'changing speed' in typical slicer output that has lots of short G1 commands with very small numbers of mm for the E movement.
        Nonetheless, for purely debugging, you could try setting Jerk to 0 and accel really low. I don't expect that to change anything, but the "proof is in the pudding".
        botundefined Bipotronicundefined 2 Replies Last reply Reply Quote 0
        • Dougal1957undefined
          Dougal1957
          Just to add a bit of clarity here the nimble he is using I am guessing from the e-steps is a V2 which has a gear reduction of 20:1 so it will be a 1.8 degree motor.
          Looking at your config I think you have the settings for the nimble widely of what is needed
          These are my settings on a V2 for you to compare
          M92 X200 Y200 Z200 E1667 ; Set steps per mm
          M566 X900 Y900 Z900 E40 ; Set maximum instantaneous speed changes (mm/min)
          M203 X18000 Y18000 Z18000 E2400 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z1000 E120 ; Set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          As you can see my motor current, acceleration, max instant speed changes, max speed and jerk are all a lot lower than yours!
          HTH
          Doug
          • Danalundefined
            Danal
            @Dougal1957 settings match up pretty well to "sanity check" calculations. Give them a try!
            • botundefined
              bot @Danal
              @Danal said in Motor don't turn at direction change:
              They only use jerk when retraction is in play, but it always uses acceleration. However, typically, the acceleration of the E axis is much greater than X and Y (it's actually not absolutely a bigger value, but the extruder doesn't need to accelerate as fast as XY) so it is never limited... ie it doesn't usually use the E accel value (except, again, during retraction).
              IMO, you have much too high of a E jerk value for your extruder. I don't use a nimble, but I use an odd extruder setup with about 4500 steps/mm and I can't go much above 1.2 mm/s E jerk or the motion is lost or the motor stalls.
              Try decreasing your M566 E value to 120, then 100, then 90, then lower if need be. I can't see lower than 60 ever being necessary, and at that point (below about 120), pressure advance will be really slowing down the XY axes to accommodate the E jerk (unless you have very conservative XY accel already).
              *not actually a robot
              • Bipotronicundefined
                Bipotronic @Danal
                @Danal as far as i know the M203 Command only limits the axis velocity. If the velocity would overreaches the maximum in M203, it would automaticly set to the given Values (20000mm/min) in M203.
                So i think it doesn't depend on that
                  Bipotronic @Danal
                  At 14rev/sec i extrude 10mm/s of Filament. I use a selfmadde Extruder which uses some kind of gear ratio. So everthing is fine at that Point. But thanks for your commitment 🙂
                    Bipotronic @Danal
                    I already tried it and it doesn't work. It seems to me that the inertia at some point, in my case arround 14rev/sec, takes over the stepper torque. Maybe a more powerful Stepper would solve the problem. Becaus i am already at the limit of the 1.6A per phase.
                      Bipotronic @Dougal1957
                      @Dougal1957 said in Motor don't turn at direction change:
                      HTH
                      Doug
                      Thanks Doug,
                      i will try it tomorrow and reply to you if it worked. By the way i'm using a V1 Nimble (1:30).
                      • Danalundefined
                        Danal @Bipotronic
                        Yah, I'm not surprised. It was a little bit of a "shot in the dark", just something easy to try.
                        Do you happen to have the model number, or the specs, on the motor that is on the extruder? And what voltage do you run, 12 or 24?
                          Dougal1957 @Bipotronic
                          @Philipp-R That config is exactly the same bar the steps/mm that I had on my V1 Nimble so the settings are valid for that as well but for a V1 I would have expected your Steps to be closer to 2700!
                          Doug
                            @Philipp-R, the problem may be that your motor is running out of torque due to insufficient supply voltage at high speeds. Use the motor EMF calculator at https://www.reprapfirmware.org/ to check this.
                              Bipotronic @Danal
                              i currently use a E3D Stepper: Comapct but Powerful version with 48mm bodylength. I also changed the motor to the smaller version with 40mm Body. I ran my motors at 24V.
                                Doug
                                I use a special Extruder which need this 1900steps/mm 🙂
