    Duet 3 Flyback on Outs 1,2,3?
    • gspetersoundefined
      gspeterso
      I'm currently working on a project using the Duet 3 6HC and 3HC. I'd like to drive some solenoids with OUT1/2/3 on the 6HC (and 3HC as well). In the documentation it says "If you connect high-current inductive loads to these outputs, you must use external flyback diodes." here: https://duet3d.dozuki.com/Wiki/Duet_3_Mainboard_6HC_Hardware_Overview. It looks like D26-D28 are flyback diodes? I couldn't find a schematic to confirm. I also noticed they are not on OUT0/1/2 on the 3HC... I could wire them externally but it'll make the wiring a little gross and would like to avoid if possible. Any guidance would be helpful.
        A Former User @gspeterso
        @gspeterso said in Duet 3 Flyback on Outs 1,2,3?:
        https://github.com/Duet3D/Hardware/tree/master/Duet3
          gspeterso
          Thanks, sorry for my ineptitude on finding the schematics.
            A Former User
            No worries! And to be fair, they've "just" set up the duet3d github repo so most searches will probably lead you to the old one.
              You are correct, flyback diodes are included on outputs 123 (but not 0) of the MB6HC but not on 012 of the EXP3HC.
