    Duet 3 setup issues
    518
    • jdumoulinundefined
      jdumoulin
      I am trying to get my DUET 3 set up but I am coming across a weird issue. I have my hotend setup on OUT1 and my bed on OUT 0 when I try to heat either I get the following within 15 seconds: Heating fault on heater X, temperature rising much slower then expected.
      Even though the system VIN is 12.6V Out0 registers 0 v when it is supposed to show 12v and out 1 is only showing 3 or 3.3v.
      Please help
        A Former User
        Does the temperature increase at all (i.e. is your thermistor working, can you heat one with your hand)?
        Out0- should show 0v when its "on". V_Out0 should show the same as V_Out0 on the Out 0 Power in terminals which you probably should wire in parallell to the other Power In terminal if you're planning on using the same powersupply.
        edit: e.g:
        jdumoulinundefined patelundefined 2 Replies Last reply Reply Quote 0
        • Danalundefined
          Danal
          please post your config.g
          jdumoulinundefined 1 Reply Last reply Reply Quote 0
            jdumoulin @A Former User
            @bearer thank you for your reply,
            Yes, this is how I have power in configured. I got a little further this morning. The bed is blowing the 15amp fuse on the board. When I put a new fuse in it the hotend voltage was 12v.
            Still not sure why the fuse is blowing. The bed worked fine with the last board and the wiring is correct.
              jdumoulin @Danal
              @Danal
              Here you go:
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Mar 19 2020 20:40:33 GMT-0400 (Eastern Daylight Time)
              M550 P"Duet 3" ; set printer name
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              M92 X80.00 Y80.00 Z4000.00 E420.00 ; set steps per mm
              M84 S30 ; Set idle timeout
              M208 X300 Y300 Z500 S0 ; set axis maxima
              M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
              M574 Y2 S1 P"io2.in" ; configure active-high endstop for high end on Y via pin io2.in
              M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
              M558 P9 C"io7.in+io8.out" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
              M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
              • Danalundefined
                Danal @jdumoulin
                @jdumoulin said in Duet 3 setup issues:
                Looks OK. Curious why bang-bang? Should work... just curious.
                Regarding your first post, and the voltages: What does Out0 read with the bed disconnected?
                  jdumoulin @Danal
                  @Danal
                  I had the bed said for PID but read that duet 3 does not handle PID yet.
                  Without the bed attached voltage is 12.4v
                  The hotend is still timing out because it is heating too slow but it is heating and getting 12v now
                  • Danalundefined
                    Danal
                    Hmmm... I may or may not be getting PID, but R3 and all the release candidates certainly have been OK with the configuration for PWM on the bed.
                    Anyway, good to see your problem at least partially resolved.
                    Now run a bed tuning, and put the resulting heater model in your config.g.
                    • patelundefined
                      patel @A Former User
                      @bearer
                      Connection say out 0 and out 0
                      Why they call out put but in wiring Diagram say In put.
                      • Danalundefined
                        Danal @patel
                        @patel said in Duet 3 setup issues:
                        @bearer
                        The flow of power on the thing called "Out0" is controlled under that name in configuration: "Out0". The thing called "Out0" is setup to handle a bed heater.
                        Physically, there is a way to get power IN to the Duet board for this whole bed heating system that is named "Out0", the middle two screw terminals.
                        There is also a way to get power OUT of the Duet board and on to the bed for this whole bed heating system that is named "Out0", the rightmost (in the diagrams above) two screw terminals.
                        Repeated another way:
                        The thing called Out0 in configuration switches the power that flows from screw terminals IN, through the board, to OUT.
