    New machine setup up 101?
    3.2k
    • iDeveloundefined
      iDevelo
      I presume you don't have Z-450 in M208 anymore?
      • iDeveloundefined
        iDevelo
        I also suggest X & Y endstops are highend so 0x0 is front left on the build plate if you homing to back right of the ft5.
        • shojidougundefined
          shojidoug
          Hi Frank, I am also putting together an FT-5 also with a duet wifi. Could you please share you completed config file? There are some differences in our setups but the majority of it would put me days ahead in the learning curve.
          Thanks very much 🙂
          • iDeveloundefined
            iDevelo
            @shojidoug:
            Thanks very much 🙂
            Here's mine:
            ;; Folgertech FT5 Configuration
            M111 S0                                        ; Debugging off
            G21                                            ; Work in millimetres
            G90                                            ; Send absolute coordinates...
            M83                                            ; ...but relative extruder moves
            M555 P2                                        ; Set firmware compatibility to look like Marlin
            M208 X0 Y0 Z0 S1                               ; Set axis minima
            M208 X305 Y304 Z410 S0                         ; Set axis maxima
            M574 Y2 X2 Z0 S0                               ; Define active high microswitches
            M558 P1 X0 Y0 Z1 H5 F120 T6000                 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
            G31 P500 X0 Y0 Z2.09                           ; Set Z probe trigger value, offset and trigger height
            M584 X0 Y1:4 Z2 E3                             ; Map to specific drives
            M569 P0 S0                                     ; Drive 0 goes forwards - X
            M569 P1 S0                                     ; Drive 1 goes forwards - Y
            M569 P2 S1                                     ; Drive 2 goes forwards - Z
            M569 P3 S1                                     ; Drive 3 goes forwards - E0
            M569 P4 S1                                     ; Drive 3 goes forwards - Y
            M350 X32 Y32 Z32 E32 I1                        ; Configure microstepping with interpolation
            M92 X160 Y160 Z798 E984.90                     ; Set steps per mm
            M566 X1200 Y1200 Z60 E120                      ; Set maximum instantaneous speed changes (mm/min)
            M203 X8000 Y8000 Z600 E1200                    ; Set maximum speeds (mm/min)
            M201 X1500 Y1500 Z500 E250                     ; Set accelerations (mm/s^2)
            M906 X1000 Y1000 Z1200 E900 I30                ; Set motor currents (mA) and motor idle factor in per cent
            M84 S30                                        ; Set idle timeout
            M143 S260                                      ; Set maximum heater temperature to 260C
            M305 P0 T100000 B3950 C0 R4700                 ; Set thermistor + ADC parameters for heated bed (Heater 0)
            M305 P1 T100000 B4388 C0 R4700                 ; Set thermistor + ADC parameters for E0 (Heater 1)
            M307 H0 A281.7 C430.4 D4.4 B0                  ; Bed PID
            M307 H1 A344.7 C122.8 D5.5 B0                  ; Hotend PID
            M563 P0 D0 H1                                  ; Define tool 0
            G10 P0 X0 Y0                                   ; Set tool 0 axis offsets
            G10 P0 R0 S0                                   ; Set initial tool 0 active and standby temperatures to 0C
            M550 PFT5                                      ; Set machine name
            M552 P0.0.0.0 S1                               ; Enable network and acquire dynamic address via DHCP
            M106 P0 S0 I0 F500 H-1                         ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S255 I0 F500 H1 T50                    ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S255 I0 F500 H1 T50                    ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            T0                                             ; Select first tool
              shojidoug
              Thank you sir! 🙂
              • FrankNPrinterundefined
                FrankNPrinter
                well it took more effort than I would like to admit but I am back online with an old win7 32 bit box so have access to system again. as promised not that it will be of any use but here is my current config. I need to work out the details for the m584 command then will get back to bltouch hopefully. Pretty sure I am missing a few adjustments like power to e1 etc. can someone check this for me and let me know what I screwed up? 🙂 I relocated 2nd z motor to series port and 2nd y motor to e1 guessing I need to update several other lines as well???
                ; Configuration file for Duet WiFi (firmware version 1.17)
                ; generated by RepRapFirmware Configuration Tool on Thu Feb 23 2017 12:18:06 GMT-0500 (Eastern Standard Time)
                G90 ; Send absolute coordinates…
                M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                M208 X256 Y269 Z450 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
                ; BLTouch
                ;M307 H3 A-1 C-1 D-1
                ;M558 P5 X0 Y0 Z1 H3 F200 T5000
                M584 X0 Y1:5 Z2:3 E4
                M569 P0 S0 ; Drive 0 goes Backwards
                M569 P1 S0 ; Drive 1 goes Backwards
                M569 P2 S0 ; Drive 2 goes Backwards
                M569 P3 S0 ; Drive 3 goes Backwards
                M569 P4 S0 ; Drive 4 goes Backwards
                M569 P5 S1 ; Drive 5 goes Forwards
                M92 X320 Y320 Z1280 E378.38 ; Set steps per mm
                M566 X900 Y900 Z900 E120 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000 Y6000 Z1000 E1200 ; Set maximum speeds (mm/min)
                M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
                M906 X1800 Y1800 Z1800 E1800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                M550 PFrankNPrninter ; Set machine name
                M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  FrankNPrinter
                  here arethe updates I have done based on m92 command
                  M92 X320 Y320 Z1280 E378.38:320 ; Set steps per mm
                  M203 X6000 Y6000 Z1000 E1200:6000 ; Set maximum speeds (mm/min)
                  M201 X500 Y20 Z250 E250:20 ; Set accelerations (mm/s^2)
                  M906 X1500 Y1500 Z1500 E1500:1500 I30 ; Set motor currents (mA)
                    FrankNPrinter
                    y and z have 1 motor going against the other so I made this change and same result. I know I missed something but am clueless… any idea what I did wrong here?
                    M584 X0 Y1:5 Z2 E4
                    M569 P5 S0 ; Drive 5 goes Backwards
                    M906 X1500 Y1500 Z1500 E1500:1500 I30 ; Set motor currents (mA) and motor idle factor in per cent
                      FrankNPrinter
                      think I found a wiring issue and fixed it. now both y motors are wired the same but they are fighting each other so something still wrong same with z
                        FrankNPrinter
                        z motors are connected to 2 z ports and y left to y port y right to e1 port
                          FrankNPrinter
                          x and y are working but z does not z motors are connected to 2 z ports and appear to be going in opposite directions. did I wire something wrong or is something configured wrong here?
                          M584 X0 Y1:4 Z2 E3
                          M569 P4 S1 ; Drive 4 goes forwards - Y
                            FrankNPrinter
                            still got something wrong hopefully with software, z motors not working and I cant figure out port numbers. can I get some clarification plz?
                              FrankNPrinter
                              don't know what I did but seems to be right now. I had to adjust some of the homing files to fix movement but so far everything appears to be moving correctly again.
                                FrankNPrinter
                                everything was working but now Y motor on left side appears to be lagging behind the right motor. very odd as they both appear to be powered up just 1 delayed. any idea if I did something wrong here. 2nd y motor is run off 2nd extruder port.
                                M574 X1 Y1 Z0 S1 ; set endstop configuration (X and Y and endstops only, at low end, active high)
                                M667 S1 ; set CoreXY mode
                                M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
                                M92 X80 Y80 Z4000 ; Set axis steps/mm
                                M92 E420:420 ; Set extruder steps/mm
                                M906 X800 Y800 Z800 E800 ; Set motor currents (mA)
                                M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
                                M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
                                M566 X600 Y600 Z30 E20 ; Maximum jerk speeds mm/minute
                                M208 X200 Y200 Z200 ; set axis maxima (adjust to suit your machine)
                                M208 X-8 Y0 Z-0.5 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
                                ; Z probe
                                M558 P1 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis
                                G31 Z1.20 P500 ; Set the probe height and threshold (put your own values here)
                                ; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
                                ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
                                M557 P0 X60 Y0 ; Four...
                                M557 P1 X60 Y165 ; ...probe points...
                                M557 P2 X222 Y165 ; ...for bed...
                                M557 P3 X222 Y0 ; ...levelling
                                ;M557 P4 X141 Y82.5 ; 5th probe point for levelling
                                ; Thermistors and heaters
                                ;*** You can use S and B parameters to define the parameters of the thermistors you are using
                                M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
                                M305 P1 R4700 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
                                M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
                                M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
                                M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
                                M570 S120 ; Increase to allow extra heating time if needed
                                  FrankNPrinter
                                  2nd y motor not always powered up. wiring looks good so going to triple check it but this has killed my printing completely. now just spews piles of molten plastic…
                                    FrankNPrinter
                                    found loose connection that was killing motor. now both y run but 1 is really loud and doesn't appear to move correctly like right motor does. anything here indicate different settings between motors?
