YAT wouldn't respond
Duet Web Control
1.0k
    Danal
    Note that @bearer and I are saying the same thing.
    Pi is optional. If you do use it (and I recommend it), follow above instructions.
      monster
      Huh!
      Information... 😄
      Guys, I do want to use Pi. I was more like complaining that big picture of result (what does what) and way to get there isn't very clear 🙂
      Now while I'm flashing another card with "DuetPi (with GUI)"
      I've inserted SD that came with Duet into Pi and I able to see that it did get IP on my router 🙂 Progress 🙂
      though that going with browser to that IP address doesn't get me anywhere. Is there a resource "What to do when Web UI is working?"
      ? 1 Reply Last reply 29 Mar 2020, 20:14 Reply Quote 0
        monster
        I forgot to mention
        My Pi has no monitor for it - I kinda hopping to get things done remotely...
          A Former User @monster
          @monster said in YAT wouldn't respond:
          I do want to use Pi
          No problem. put a file called ssh on the FAT32 partition of the Raspberry Pi image. Just ssh, no extension. That enables the ssh server so you can log in with your favourite ssh client (putty if on windows).
          When the image of your choice has been flashed, the Duet 3 can be connected to via the hostname "duet3". It comes preconfigured with mDNS enabled (via avahi), SSH activated and the standard credentials "pi" and "raspberry". To set up WiFi, you can edit "wpa_supplicant.conf" on the SD card (first partition).
          if you need wireless network set up, you put another file on the card. wpa_supplicant.conf with your country code and wifi details in it, example below
          ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
          update_config=1
          country=UK
          network={
              ssid="your network name"
              psk="your network key"
            monster
            Current status is this:
            ✅ A - Original Duet card
            When this card is in Pi - I got Web UI working (uploaded config.g generated by https://configtool.reprapfirmware.org ), can't yet move any motor.
            ❌ B - Another SD card flashed with "DuetPi (with GUI)" and on top of that put file "ssh" in root, "wpa_supplicant.conf" in root.
            When this card is in Pi - no IP address obtained from router... 😞
            I guess question of this topic is mostly solved - some way to connect is working 🙂
            Thank you for your help!!!
            P.S. Do I upload all files that configtool.reprapfirmware.org made to Web UI??? All to root? Or "sys" dir to root? Or?
            undefined ? 2 Replies Last reply 29 Mar 2020, 23:14 Reply Quote 0
              Danal @monster
              The card etched from the image should have a 'boot' partition (B Boot, not R Root). The two files go in that partition, no subdirectories.
              DO NOT UNZIP
              Just upload the zip file itself via the "system" tab, "upload system files" button.
              undefined 1 Reply Last reply 30 Mar 2020, 09:59 Reply Quote 0
                the simple solution is use card A; although they should be the same; and not need the ssh file (unless you use a vanilla raspbian image). and if card A worked without wpa_supplicant.conf I'm guessing you're not using wifi?
                That the motors don't move is probaly down to configuration, as they won't move until homed.
                (you can override with
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M564_Limit_axes
                https://duet3d.dozuki.com/Wiki/Gcode#Section_G92_Set_Position
                https://duet3d.dozuki.com/Wiki/Gcode#Section_G0_G1_Move (G0 H2) )
                undefined 1 Reply Last reply 30 Mar 2020, 09:01 Reply Quote 0
                  monster @A Former User
                  @bearer said in YAT wouldn't respond:
                  I would like to use WiFi! As this extra eithernet wire is... is an extra wire 😄
                  Yes, when I attempt to use UI to move the motors it says that nothing is homed. And I guess in order to home axis's I'd need to marry end stops with their motors/axis's, right? Last night I was trying to find how - failed 😭
                  Thank you for links - I'll study them today!
                  ? 2 Replies Last reply 30 Mar 2020, 09:09 Reply Quote 0
                    if you can log in using ethernet just run sudo raspi-config as it may be simpler than to edit /etc/wpa_supplicant/wpa_supplicant.conf otherwise you'll just need to put the file on the correct partition, there should be a config.txt file on the correct partition (along with a bunch other files bcm27* and so on)
                    undefined 2 Replies Last reply 30 Mar 2020, 09:57 Reply Quote 0
                      correct
                      https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
                        sudo raspi-config
                        A recall from yesterday.
                        Yesterday I've tried that - I get from config tool:
                        "Could not communicate with wpa_supplicant"
                        Tried again now - same result.
                        Then I used way of pain (AKA vim) 😂 to edit
                        then rebooted, still no WIFI connection.
                        Obviously this is about partitions that you referred about. I must admit I'm not fully understand neither linux architecture not filesystem of it.
                        ? 2 Replies Last reply 30 Mar 2020, 10:05 Reply Quote 0
                          monster @Danal
                          @Danal said in YAT wouldn't respond:
                          DO NOT UNZIP
                          Done that! Thank you!
                            could be a lacking country code is preventing it bringing up the wifi interface (the country code is there for regulatory approval, no code, no wifi to, avoid using channels outside local regulatory approvals)
                            undefined 1 Reply Last reply 30 Mar 2020, 10:28 Reply Quote 0
                              Then I used way of pain (AKA vim) to edit
                              nano is a bit more user friendly if vi is troublesome
                              suspect the content is either wrong or incomplete.
                              i'd try the below, then sudo raspi-config after rebooting.
                              cat << EOF | sudo tee -a /etc/wpa_supplicant/wpa_supplicant.conf
                              update_config=1
                              country=UK
                              EOF
                              undefined 1 Reply Last reply 30 Mar 2020, 10:30 Reply Quote 0
                                Ahaa 🙂
                                True, my region settings were unchanged.
                                But still 😞
                                If i go to config / P4 (Localization Options) / I4 (Change Wifi country) I still get:
                                  update_config=1
                                  country=UK
                                  EOF
                                  Manually edited country setting - no changes.
                                    A Former User
                                    hmm, something is amiss; still not sure why there is a difference.
                                    given you have ethernet access you could use something like ngrok to get someone you trust to have a look at it for you. if its still unresolved tomorrow I could take a look (although providing access, and ultimately root access, to random strangers on the internet is isn't something i'd reccomend)
                                      Danal
                                      Yeah, this is really odd. If the SD was built from an image, the WPA stuff should work.
                                      Depending on what you want to do... you might consider building an SD again, starting from the Duet image. Once you've done it at least once, it goes pretty quickly.
                                      These are my self-notes for building a new card. Anything that does not start with a # is a potential copy/paste:
                                      # Get your Pi booted and on your network:
                                      # Download image (not lite) from https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_DuetPi
                                      # Do not unzip it.
                                      # Etch image to SD card. (search google for balena etcher)
                                      # Ignore windows error messages for the next drive letter after your SD. DO NOT format.
                                      # On the SD card, edit wpa_supplicant.conf for your network
                                      # On the SD card, create a file named 'ssh'. Empty is fine.
                                      # Insert SD in Pi and power up. First boot takes an extra minute or two.
                                      # Find IP address (varies a lot by router) or try "duet3.local"
                                      # From your PC, enter:
                                      ssh pi@x.x.x.x
                                      # Default password is raspberry CHANGE IT after you connect for the first time!
                                      # From the Pi command prompt:
                                      passwd
                                      #You now have a running Pi, but it is not completely built
                                      # to run a Duet 3 printer yet.
                                      #Set up OS options for Duet Software Framework:
                                      sudo raspi-config
                                      # Navigate to 5 interface options, then P4 SPI, and 5 again, P3 VNC
                                      # Verify via
                                      ls /dev/spidev*
                                      # Look for /dev/spidev0.0
                                      # You may also wish to set country, time zone, etc. with raspi-config
                                      # Now complete setup for duetsoftwareframework.
                                      wget -q https://pkg.duet3d.com/duet3d.gpg
                                      wget -q https://pkg.duet3d.com/duet3d-unstable.list
                                      sudo mv duet3d.gpg /etc/apt/trusted.gpg.d/
                                      sudo mv duet3d-unstable.list /etc/apt/sources.list.d/duet3d-unstable.list
                                      sudo chown root:root /etc/apt/trusted.gpg.d/duet3d.gpg
                                      sudo chown root:root /etc/apt/sources.list.d/duet3d-unstable.list
                                      sudo apt-get update
                                      sudo apt-get install apt-transport-https
                                      sudo apt-get install duetsoftwareframework
                                      # Verify you can connect to DWC via web server.
                                      # If you have configuration files (config.g, tool macros, etc) use DWC to upload them now.
                                      # Update the Pi itself:
                                      sudo apt-get update
                                      sudo apt-get upgrade (this may take 15 to 60 minutes)
                                      # Reboot is not absolutely required... but...
                                      sudo reboot
                                      # End of required install for Duet 3 Pi #
                                        That helped! Got WiFi working!
                                          A Former User
                                          out of curiosity - which operating system are you running; not windows presumably or?
                                          undefined 1 Reply Last reply 1 Apr 2020, 18:54 Reply Quote 0
                                          14 out of 31
