    DSF 1.3.1 (unstable) released
    DSF Development
    9
    40
    1.9k
      dc42 administrators @gtj0
      @gtj0 said in DSF 1.3.1 (unstable) released:
      It looks like the model updates for temperature are a little "different".
      I'm seeing repeated updates for the same temperature. It's almost as though the temp is changing but it's the same value being reported. Then every once in a while, the value will actually change.
      Model variables marked "live" in the object model are reported by RRF to DSF continuously. This includes temperatures, axis coordinates, current/requested speed, voltages and several other variables. That's probably what you are seeing.
      • gtj0undefined
        gtj0 @dc42
        @dc42 Hmmm. I think what's throwing me off is that sometimes objects are there with changing values, sometimes there without values, sometimes not there at all, and sometimes there with static values.
        In this example, "boards" is only there if the vIn has changed but "fans" is always there with empty values. "tools" is always there with the active and standby temps even though they never change.
          "boards": [
              "vIn": {
                "current": 25.3
          "fans": [
            null,
            null,
            null,
            null,
            null,
            null,
            null,
          "inputs": [
              "lineNumber": 130116,
              "state": "waiting"
          "job": {
            "duration": 4029.3,
            "filePosition": 3535962,
            "layerTime": 4.1
          "move": {
            "axes": [
                "userPosition": 49.28
                "machinePosition": -24.88,
            "extruders": [
                "position": 10425.8
          "sensors": {
            "probes": [
                "value": [
                  553
          "tools": [
              "active": [
                225
              "standby": [
                160
          Yes, that's because the fan RPMs and tool temperatures are flagged as live in the OM - although I thought the vin fields of boards was live too.
          • gtj0undefined
            gtj0 @dc42
            @dc42 I'm not quite following. Fan RPMs are marked as live but they're not showing. In my case, they're zero anyway since I don't have the tach inputs connected but shouldn't they still show as zero? What about fan speeds? Are they live? The tool active and standby temps are considered live so they always show but the actual heater temps which should also be considered live don't show unless changed. It's very confusing.
            I think we need to hear from @chrishamm on what "live" means to the DSF.
            • gruenundefined
              gruen
              nothing works, power cycle doesn't help:
              Duet Control Server v1.3.1
              Written by Christian Hammacher for Duet3D
              Licensed under the terms of the GNU Public License Version 3
              [info] Settings loaded
              [info] Environment initialized
              [warn] Bad data checksum (expected 0xa23d, got 0x5ef8)
              [warn] Restarting transfer because the number of maximum retries has been exceeded
              [error] Duet is not available
              • gtj0undefined
                gtj0 @gruen
                @gruen I have to ask... was it working before and with which version?
                Can you paste the contents of /opt/dsf/conf/config.json.
                Can you change the "LogLevel" entry to "debug" and restart the DCS and paste the output.
                gruenundefined 1 Reply Last reply Reply Quote 0
                • gruenundefined
                  gruen @gtj0
                  @gtj0
                  here is the config.json
                    "LogLevel": "info",
                    "SocketDirectory": "/var/run/dsf",
                    "SocketFile": "dcs.sock",
                    "Backlog": 4,
                    "SocketPollInterval": 2000,
                    "BaseDirectory": "/opt/dsf/sd",
                    "HostUpdateInterval": 4000,
                    "MaxMessageAge": 60,
                    "SpiDevice": "/dev/spidev0.0",
                    "SpiFrequency": 8000000,
                    "SpiTransferTimeout": 500,
                    "MaxSpiRetries": 3,
                    "SpiPollDelay": 25,
                    "SpiPollDelaySimulating": 5,
                    "GpioChipDevice": "/dev/gpiochip0",
                    "TransferReadyPin": 25,
                    "BufferedPrintCodes": 32,
                    "BufferedMacroCodes": 16,
                    "MaxBufferSpacePerChannel": 1536,
                    "ModelUpdateInterval": 250,
                    "MaxMachineModelLockTime": -1,
                    "FileInfoReadBufferSize": 8192,
                    "FileInfoReadLimitHeader": 12288,
                    "FileInfoReadLimitFooter": 262144,
                    "MaxLayerHeight": 0.9,
                  removed: "LayerHeightFilters"
                  -- Logs begin at Sat 2020-04-04 22:30:02 CEST, end at Sat 2020-04-04 22:30:59 CEST. --
                  Apr 04 22:30:05 Duet6 systemd[1]: Started Duet Control Server.
                  Apr 04 22:30:09 Duet6 DuetControlServer[335]: Duet Control Server v1.3.1
                  Apr 04 22:30:09 Duet6 DuetControlServer[335]: Written by Christian Hammacher for Duet3D
                  Apr 04 22:30:09 Duet6 DuetControlServer[335]: Licensed under the terms of the GNU Public License Version 3
                  Apr 04 22:30:12 Duet6 DuetControlServer[335]: [info] Settings loaded
                  Apr 04 22:30:12 Duet6 DuetControlServer[335]: [info] Environment initialized
                  Apr 04 22:30:12 Duet6 DuetControlServer[335]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f)
                  Apr 04 22:30:12 Duet6 DuetControlServer[335]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                  Apr 04 22:30:12 Duet6 DuetControlServer[335]: [error] Duet is not available
                  Apr 04 22:30:12 Duet6 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 04 22:30:17 Duet6 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                  Apr 04 22:30:17 Duet6 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 1.
                  Apr 04 22:30:17 Duet6 systemd[1]: Stopped Duet Control Server.
                  Apr 04 22:30:17 Duet6 systemd[1]: Started Duet Control Server.
                  Apr 04 22:30:18 Duet6 DuetControlServer[737]: Duet Control Server v1.3.1
                  Apr 04 22:30:18 Duet6 DuetControlServer[737]: Written by Christian Hammacher for Duet3D
                  Apr 04 22:30:18 Duet6 DuetControlServer[737]: Licensed under the terms of the GNU Public License Version 3
                  Apr 04 22:30:19 Duet6 DuetControlServer[737]: [info] Settings loaded
                  Apr 04 22:30:19 Duet6 DuetControlServer[737]: [info] Environment initialized
                  Apr 04 22:30:19 Duet6 DuetControlServer[737]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f)
                  Apr 04 22:30:19 Duet6 DuetControlServer[737]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                  Apr 04 22:30:19 Duet6 DuetControlServer[737]: [error] Duet is not available
                  Apr 04 22:30:19 Duet6 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 04 22:30:25 Duet6 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                  Apr 04 22:30:25 Duet6 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 2.
                  Apr 04 22:30:25 Duet6 systemd[1]: Stopped Duet Control Server.
                  Apr 04 22:30:25 Duet6 systemd[1]: Started Duet Control Server.
                  Apr 04 22:30:25 Duet6 DuetControlServer[1054]: Duet Control Server v1.3.1
                  Apr 04 22:30:25 Duet6 DuetControlServer[1054]: Written by Christian Hammacher for Duet3D
                  Apr 04 22:30:25 Duet6 DuetControlServer[1054]: Licensed under the terms of the GNU Public License Version 3
                  Apr 04 22:30:26 Duet6 DuetControlServer[1054]: [info] Settings loaded
                  Apr 04 22:30:27 Duet6 DuetControlServer[1054]: [info] Environment initialized
                  Apr 04 22:30:27 Duet6 DuetControlServer[1054]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f)
                  Apr 04 22:30:27 Duet6 DuetControlServer[1054]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                  Apr 04 22:30:27 Duet6 DuetControlServer[1054]: [error] Duet is not available
                  Apr 04 22:30:27 Duet6 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 04 22:30:32 Duet6 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                  Apr 04 22:30:32 Duet6 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 3.
                  Apr 04 22:30:32 Duet6 systemd[1]: Stopped Duet Control Server.
                  Apr 04 22:30:32 Duet6 systemd[1]: Started Duet Control Server.
                  Apr 04 22:30:32 Duet6 DuetControlServer[1227]: Duet Control Server v1.3.1
                  Apr 04 22:30:32 Duet6 DuetControlServer[1227]: Written by Christian Hammacher for Duet3D
                  Apr 04 22:30:32 Duet6 DuetControlServer[1227]: Licensed under the terms of the GNU Public License Version 3
                  Apr 04 22:30:34 Duet6 DuetControlServer[1227]: [info] Settings loaded
                  Apr 04 22:30:34 Duet6 DuetControlServer[1227]: [info] Environment initialized
                  Apr 04 22:30:34 Duet6 DuetControlServer[1227]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f)
                  Apr 04 22:30:34 Duet6 DuetControlServer[1227]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                  Apr 04 22:30:34 Duet6 DuetControlServer[1227]: [error] Duet is not available
                  Apr 04 22:30:34 Duet6 systemd[1]: duetcontrolserver.service: Succeeded.
                  Apr 04 22:30:52 Duet6 systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                  Apr 04 22:30:52 Duet6 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 4.
                  Apr 04 22:30:52 Duet6 systemd[1]: Stopped Duet Control Server.
                  Apr 04 22:30:52 Duet6 systemd[1]: Started Duet Control Server.
                  Apr 04 22:30:53 Duet6 DuetControlServer[1241]: Duet Control Server v1.3.1
                  Apr 04 22:30:53 Duet6 DuetControlServer[1241]: Written by Christian Hammacher for Duet3D
                  Apr 04 22:30:53 Duet6 DuetControlServer[1241]: Licensed under the terms of the GNU Public License Version 3
                  Apr 04 22:30:54 Duet6 DuetControlServer[1241]: [info] Settings loaded
                  Apr 04 22:30:55 Duet6 DuetControlServer[1241]: [info] Environment initialized
                  Apr 04 22:30:55 Duet6 DuetControlServer[1241]: [warn] Bad data checksum (expected 0x31c7, got 0xe55f)
                  Apr 04 22:30:55 Duet6 DuetControlServer[1241]: [warn] Restarting transfer because the number of maximum retries has been exceeded
                  Apr 04 22:30:55 Duet6 DuetControlServer[1241]: [error] Duet is not available
                  Apr 04 22:30:55 Duet6 systemd[1]: duetcontrolserver.service: Succeeded.
                  • gruenundefined
                    gruen
                    RC5 works for me, how can I downgrade?
                    • wilrikerundefined
                      wilriker @gruen
                      @gruen Have your tried reflashing the Duet? I've seen this before sometimes and strangely (coincidentally?) it only went away after flashing the firmware again.
                      Manuel
                      My Tool Collection
                      • tobias_munichundefined
                        tobias_munich
                        @chrishamm @dc42 thank you guys,
                        after updating via apt upgrade the system is running again.
                        a new test print is running.
                        Update: After 1h of printing DCS lost the connection again
                        Hypercube-Evolution, Dual-Z, Nimble v2, Orion Piezo
                        Duet3, DuetWifi, Raspberry Pi 4, 7 inch HDMI Display, Panel-Due
                        Firmware: RepRapFirmware for Duet 3 MB6HC 'always the latest release'
                        • gtj0undefined
                          gtj0
                          The default SpiFrequency in /opt/dsf/conf/config.json changed from 2000000 (2MHz) to 8000000 (8MHz) with the recent release. Try changing it back to 2000000 and see what happens. Experiment to see what the fastest speed you can reliably run at.
                          • chrishammundefined
                            chrishamm administrators
                            @tobias_munich Sorry to hear you are having problems. Can you check for error messages when DCS disconnected? Can you share the output of M122?
                            @gruen Please do what @gtj0 said.
                            Duet software engineer
                            • gtj0undefined
                              gtj0
                              @chrishamm Do you want me to open github issues for the print time and model issues I mentioned above?
                              • mikedahlgrenundefined
                                mikedahlgren
                                @chrishamm Shared elsewhere but here is the results of "sudo journalctl -u duetcontrolserver -en 100 --no-pager"
                                Apr 06 18:02:00 duet3 DuetControlServer[13291]: Duet Control Server v1.3.1
                                Apr 06 18:02:00 duet3 DuetControlServer[13291]: Written by Christian Hammacher for Duet3D
                                Apr 06 18:02:00 duet3 DuetControlServer[13291]: Licensed under the terms of the GNU Public License Version 3
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [info] Settings loaded
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [info] Environment initialized
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [warn] RepRapFirmware got a bad header checksum
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [info] Connection to Duet established
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [info] IPC socket created at /var/run/dsf/dcs.sock
                                Apr 06 18:02:01 duet3 DuetControlServer[13291]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: [fatal] Abnormal program termination
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: [fatal] Update task faulted
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: System.ArgumentException: Requested value 'fault' was not found.
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                                Apr 06 18:02:02 duet3 DuetControlServer[13291]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                                  @mikedahlgren Thanks, I've got a fix ready and will release it later this week. Until then the only way to get DCS back working is to reset the Duet 3 using the push button and to wait a moment.
                                  @gtj0 You're right about the printing time and Simplify3D, I'm looking into it. As for the diffs it's all looking good and appears like what DWC would expect, but it's odd that you are seeing the tool temperatures being transmitted over and over again even though nothing has changed. I just tried to reproduce it and I could do this, so I'll fix it as well. Thanks for letting me know!
                                  PS: It's actually Simplify3D that tried to be smart, they're now printing hour instead of hours so my regex doesn't work any more. I'll update it.
                                    mikedahlgren
                                    @chrishamm Thanks you!
                                    • gtj0undefined
                                      gtj0
                                      @chrishamm Can you also comment on the other model oddities like the "fans" object showing in an update but with all empty values. It's kinda confusing because some of the things the RRF model considers "live" show up on every update but others which are also "live" don't.
                                        chrishamm administrators @gtj0
                                        @gtj0 The whole purpose of the patch-mode subscription is to reflect changes. So it is intended to transmit empty objects if none of the properties of a list item have changed, else you would not be able to tell when the size of a list has changed (e.g. because you decided to delete a tool or something else). Well, in your case you shouldn't be seeing any empty or null items either and it's related to the bug I'm about to fix, so don't worry about it.
                                        PS: Here the new regex for S3D that should work, feel free to give it a try:
                                        Build time: ((?<h>\d+) hour(s)?\s*)?((?<m>\d+) minute(s)?\s*)?((?<s>(\d+) second(s)?))?
                                        • gtj0undefined
                                          gtj0 @chrishamm
                                          @chrishamm Cool! I'll give the regex a try.
                                          • gtj0undefined
                                            gtj0 @gtj0
                                            AHHHHH. The fact that all those <> etc characters need to be escaped in config.json is really annoying. I'll wait for you to update the default file in the repo. 🙂
