    New PanelDue 1.16beta1 firmware
    Firmware installation
    13
    28
    4.3k
    • DADIYundefined
      DADIY
      Hi David.
      Are there any instructions for setting up eclipse to build this? I'm hoping its easier than setting up eclipse for building the Duet firmware as I never managed to get that to work.
        @DADIY:
        Hi David.
        How long ago did you try to set up Eclipse for building RRF? It used to be much more difficult than it is now because of the need to use the temperamental Arduino plugin.
        I use the same configuration (including cross gcc compiler) to build PanelDue that I use to build RRF and associated projects, just a different workspace.
        • DADIYundefined
          DADIY
          Probably last November I last had a go. Never managed to get it compile anything though 😞
          • schneik80undefined
            schneik80
            updated and no issues. very nice improvements.
            • Fickertundefined
              Fickert
              Quick question in regards to updating. I hit erase and reset while plugged into my pc with a usb cable that only provides power. Now I cannot install the same driver I used for the Duet. Am I missing something?
              As well, I cannot figure out how to download the windows version of Bossa. My pc always prompts me with it cannot open the .gz file.
              Regards,
              Dustin
                You can find the Windows version of bossac in the Tools folder of my github RepRapFirmware repository. I don't think you need a driver if you are running Windows 10.
                • Loffy770undefined
                  Loffy770
                  I have upgraded and noticed that Paneldue does often stop to read the temp while the webinterface displays temp correctly..
                  • celulariundefined
                    celulari
                    Thanks for the update!!! It Is possible yo add an option to turn off the screen? It's so bright on the dark 🙂
                    Thanks!
                    • Doc_Penguundefined
                      Doc_Pengu
                      Hello David,
                      Sorry if this is on wrong place. I have tried to search on forum, but not come across this problem.
                      I have little problem with my 7 inch screen and PanelDue.
                      Touch screen seems to be thinking thats it on portrait mode,
                      so….
                      When 1st cal point comes to screen to press, i need to press point where 2nd one comes (does not care if i try press in right point over the black spot) and when 2nd cal point comes, i need to press where 3rd point comes....
                      Touch screen is rotated 90 degrees. End of this calibration process i get all coordinates wrong 😞
                      I seems to be thinking that in original touch screen code to Arduino, there in some sort on way to turn this right ?
                      What needs to be done to your code to correct touch screen rotation ?
                      Is it possible to get BIN file with this already corrected ?
                      I have tried to get my Eclipse installation working, i get ELF file end of compiling. BIN file goes 'missing', even it's on Post-build steps settings.
                      Thanks
                      Mark
                        Where do you get your 7" TFT panel from? Are you definitely using the code for the 7" panel?
                        The Eclipse project has a post-build step configured to convert the .elf file into a .bin file.
                        • DADIYundefined
                          DADIY
                          I managed to get the PanelDue firmware to build but there were a couple of extra steps required that were not in the instructions that I found I needed to do.
                          For Eclipse I had to install the following extras under Help - Install New Software -
                          Arduino C++ Tools - org.eclipse.cdt.arduino.feature.group
                          C/C++ Development Tools - org.eclipse.cdt.feature.group
                          C/C++ GCC Cross Compiler Support - org.eclipse.cdt.build.crossgcc.feature.group
                          To get the elf file to convert to the bin file, the Post Build Steps under Project Properties -> C/C++ Build -> Settings Post Build Steps was updated to
                          arm-none-eabi-objcopy -O binary ${workspace_loc:/${ProjName}/${ConfigName}}/PanelDue-7.0.elf ${workspace_loc:/${ProjName}/${ConfigName}}/PanelDue-7.0.bin
                          The original used ${ProjName}-7.0.elf for the filename which was evaluating to PanelDueFirmware-7.0.elf but the output from the compile generated PanelDue-7.0.elf
                          Also the Arduino 1.5.8 from arduindo.cc didn't include the tools but I already had these installed elsewhere.
                          • DADIYundefined
                            DADIY
                            Check your makefile , at the end there is the command that converts the .elf to the bin, you may find that if you run this manually that your path in the command is slightly wrong.
                            @Doc_Pengu:
                            Hello David,
                            so….
                            Thanks
                            Mark
                              Doc_Pengu
                              @dc42:
                              Panel I'm using is from Aliexpress, friend of my bought it while back for some Arduino project, but it was never used.
                              So I ended to have it.
                              I have tried all BIN files from github repo for 7 inch panel and all of the seems to have same 'problem' with touchscreen rotation.
                              Need to look my Eclipse settings and get BIN file conversion working.
                              Any tips what part of PanelDue code could rotate touchscreen coordinations ?
                              Mark
                                Doc_Pengu
                                @DADIY:
                                Thank you for the tip, that did do the job.
                                Mark
                                  Doc_Pengu
                                  All sorted now, got the touchscreen working correctly.
                                  All I did is swapped order witch X and Y coordinates from touchscreen is read in UTouch.cpp
                                  [[language]]
                                  // If the panel is touched, return the coordinates in x and y and return true; else return false
                                  bool UTouch::read(uint16_t &px, uint16_t &py, uint16_t * null rawX, uint16_t * null rawY)
                                  	bool ret = false;
                                  	if (!portIRQ.read())			// if screen is touched
                                  		portCS.setLow();
                                  		delay_us(100);				// allow the screen to settle
                                  		uint16_t ty;				// <- was tx
                                  		if (getTouchData(false, ty))	        // <- was tx
                                  			uint16_t tx;			// <- was ty
                                  			if (getTouchData(true, tx))	// <- was ty
                                  Thank you David for nice add on to DuetWifi
                                  Mark
