Change Wifi via Config?
Firmware installation
3.6k
    AS-3D Druck
    Hi there,
    i recently got a new AVM Router and forgot before to change my Wifi Settings and i wonder
    is there a config File or something to change the Password without connecting my Duet Wifi to my PC?
    Best regards
    AS-3D Druck / Andre
      A Former User
      using a macro is the recommended way https://forum.duet3d.com/post/139882
      but that thread also has examples of using config.g which is not recommended.
        AS-3D Druck
        I know, but my USB Port on my Duet Wifi is broken and i need to do it from my SD Card.
        Best regards
        AS-3D Druck / Andre
          A Former User
          seems the trick was to add the G4 delay, but the details are in the thread i linked to.
            AS-3D Druck
            So if i just add this to my config at the Bottom it should work right?
            M98 P0:/Macros/WifiReset.g
            G4 S5 ; wait 5 seconds
            M98 P0:/Macros/WifiClear.g
            (I created the Files i call here with the Code from the Linked Post)
            Best regards
            AS-3D Druck / Andre
              A Former User
              @bearer said in Can't access wifi:
              That ***** me off... so I tried on a board here.
              Think the second G4 is redundant, but uncomment if it still doesn't work. Confirmed working from config.g even though its baaaaaad mojo.
              M552 S-1
              M552 S0 ; take AP out of reset, just in case
              G4 S1
              M588 S"*"; forget all previous access point info
              ;G4 S1
              M587 S"---" P"---"
              M552 S1
              replace ---- with your ssid and password will clear old and add a new network. remove/comment out M588 to prevent clearing old networks.
                AS-3D Druck
                Didn't work i don't know why...
                tryed at the End of my config.g File:
                first:
                ; WifiReset.g
                ; Use in case wifi module is not running. (Blue light off)
                M291 R"Reset wifi module? Y/N" P"Caution. Will cause pause in print" S3 T10
                M552 S0 ; Disable network module
                M552 S1 ; Enable network module
                M291 P"Wifi module reset. Check console or DWC."
                second:
                ;WifiClear.g
                ; Clear all wifi networks
                M291 R"Clear WIFI networks? Y/N" P"Caution. New network must be added." S3 T10
                M588 S"*" ; Clear all saved wifi networls
                M291 R"WIFI networks forgotten." P"You must add a new WIFI network."
                third:
                M98 P0:/Macros/WifiAdd.g
                ; WifiAdd.g
                ; Add default wifi network
                M291 R"Add default WIFI network? Y/N" P"This will add duetwifi access point." S3 T10
                M587 S"myNetworkName" P"NetworkPassword" ; Add duetwifi SSID to remembered networks list
                M552 S1 ; reenable wifi module
                M291 R"NetworkName added." P"Check console to verify IP address."
                What was wrong? (And yes i changed my NetworkName and NetworkPassword to my)
                Best regards
                AS-3D Druck / Andre
                  A Former User
                  hmm, seems i didn't look too closely at the macro Phaedrux made - M291 without a display might not be a good fit, comment out and it should proceed.?
                    AS-3D Druck
                    tried it again without the line M291 and no success
                    Best regards
                    AS-3D Druck / Andre
                      A Former User
                      The down side is the error messages will be on the usb console; if you have a 3.3v usb ttl adapter you can hook up to the PanelDue port
                      I can only attest to the 7 lines I tried myself beyond that idk.
                        AS-3D Druck
                        So no other way?
                        Best regards
                        AS-3D Druck / Andre
                          Three other ways:
                          1. If you have a PanelDue, you can use it to enter the M587 and other commands.
                          2. In your config.g file include M552 S0 to put the wifi module into Idle mode. Then set up a trigger on one of the endstop inputs using the M581 command, and in the trigger file execute the M587 command, followed by M552 S1.
                          3. Recent 3.01RC firmware releases run the file sys/runonce.g after running config.g. You can put the M587 and other commands in runonce.g. The file is deleted after it has been run.
                          undefined 1 Reply Last reply 6 Apr 2020, 21:39 Reply Quote 1
                            AS-3D Druck @dc42
                            @dc42 The only option that i have is the 2. Way cause it runs on Version 2. something and i got no external Display.
                            I understand kind of what you want but don't know how to do it.
                            Best regards
                            AS-3D Druck / Andre
                            undefined ? 2 Replies Last reply 6 Apr 2020, 22:38 Reply Quote 0
                              Phaedrux Moderator @AS-3D Druck
                              @AS-3D-Druck said in Change Wifi via Config?:
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_Configure_external_trigger
                              Does this help?
                              @bearer said in Change Wifi via Config?:
                              The macros from that other thread assume you have a PanelDue to be able to use them as is, or a USB terminal with some modification.
                                A Former User @AS-3D Druck
                                if you tried
                                M552 S-1
                                G4 S1
                                ;G4 S1
                                M587 S"---" P"---"
                                M552 S1
                                i suspect there is a problem either with the duet or exteral to the duet, because it worked when i tried it on 2.02 and 2.05
                                are there any special characters in your ssid or key, hidden ssid, brand of router, type of encryption etc?
                                4 out of 15
