Webserver won't start
Just found an old switch...will try tomorrow! Not sure about how to set everything including tftpd up, but will find out eventually.
its been a while but from memory
- connect computer to switch
- set a static ip for your wired network https://www.google.com/search?q=window+static+ip
- ip 10.10.10.1
- netmask 255.255.255.0
- configure tfpd64 by clicking the setup button (bottom center of the window)
- open the global tab and make sure dhcp is ticked
- open the dhcp tab and fill in
- ip pool start address 10.10.10.10
- size of pool 10
- mask 255.255.255.0
- bind dhcp to this address 10.10.10.1
- close settings and restart tftpd64.
- start wireshark and begin capture
- plug in network cable for the duet
- power up the duet.
- enable the network on the duet with either config file on sd card or by sending M552 S1
- pray
you can use whatever private address you like, using 10 is faster to type imho, but techincally its a little dirty to use that netmask with that class of network but hopefully we don't have to go off topic on that any more than i just did...
I did all of the steps provided, now the green led is blinking less frequently, but still doesn't work.
and presumably no packets shown if you enter bootp as a display filter, some arp traffic likely, but doubt its relevant
neither bootp nor dhcp show up anything.
bootp catches both (seems dhcp was added since last time i updated wireshark).
anyways, the horse is sufficiently beaten and still dead.
@bearer @droftarts thanks for all of your time and help! I highly appreciate it!
I just ordered an ethernet module...will keep you updated, as soon as it arrives! -
@Haffwalker said in Webserver won't start:
How can I close the thread?
awesome!
no need to close, but you can mark it as solved.
https://forum.duet3d.com/topic/7773/forum-feature-mark-as-question-solved?_=1586512391010
