    Duet 3 hc6 firmware '''issues''
    Firmware installation
    2.5k
      A Former User
      The problem now is.
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      Has all the data in it dont know if it is the correct once since there is no compatible webcontroll apparently.
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1
      Routter can see duet just fine, the problem of geting to webcontroll still remains.
        A Former User
        can you confirm the filesytem is fat32?
        or connect to your duet with usb cable so we can run some commands in a terminal?
        (but i do suspect the card is okay, if you're getting an ip address and a response from the duet it should have read your config.g file)
          A Former User
          Yes i did format the system as fat32
            A Former User
            and i can run commeands via usb no problem
              A Former User
              Is this things even connected properly?
              -The SD card is in the SD card slot.
              -USB is connected.
              -Ethernet cable is connected.
              -The duet is only powered vai the usb cable, dont have a laptop and am not gonna rist a groundloop.
              -Printter is fully asembled, only disconected PSU to avoid a posible surge, PSU is not connected to outlet.
              -FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_VERSION: 3.0beta12 ELECTRONICS: Duet 3 MB6HC FIRMWARE_DATE: 2019-11-02b1, note i did not find a coresponding version of duetwebcontroll.
              version of webcontroll the SD card is 2.04
              What now?
                A Former User
                M20 P/www in the usb termimal should give some insight as to why it cant fine the web interface.
                  A Former User
                  @bearer said in Duet 3 hc6 firmware '''issues'':
                  M20 P/www
                  M20 P/www
                  Begin file list
                  NONE
                  End file list
                  ok
                    A Former User
                    well, that explains it; according to the duet the www folder is empty.
                    Duet Web Control 2.0.4 is the correct version for IRMWARE_VERSION: 3.0beta12 but it seems the files are not placed correctly.
                    can you put the SD card in your computer and run tree /f d:\ from a command line if you're using windows (change d:\ to the drive that is your SD card) and compare to what I posted earlier; and make it match if not.
                    if the card has more than one partition, pay attention to using the first one or format the card using the https://www.sdcard.org/downloads/formatter/ tool and copy the files over again.
                    hopefully that'll help or someone else can assist you as i'm off for a bit.
                      droftarts administrators @A Former User
                      @Torppa You haven't put the DWC files in the www folder, then. Download DuetWebControl-SD.zip from https://github.com/chrishamm/DuetWebControl/releases/tag/2.1.1 , unzip it and copy files into the www folder (if they're not already in one to just copy across).
                      Setting up the SD card is exactly the same on Duet 3 standalone as on Duet 2. See https://duet3d.dozuki.com/Wiki/SD_Card and https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure
                        A Former User
                        M20 P/www
                        Begin file list
                        favicon.ico
                        index.html
                        css
                        fonts
                        js
                        End file list
                        ok
                        Had to format it, it had 7 partitions for some reason.
                          A Former User
                          Now i got to the duet webcontroll page.
                            @Torppa said in Duet 3 hc6 firmware '''issues'':
                            Often Windows 'Quick' format does strange things to SD cards. Using the SD formatting tool is best.
                              A Former User
                              Now the thing randomly looses connection webcontroll and crashes cant change the IP to a statick one since it crashes intantly when i try i.
                                A Former User
                                Well this is just Nice...
                                After crashing
                                M20 P/www
                                Begin file list
                                NONE
                                End file list
                                ok
                                Windows does not regognize sd card at all.
                                  @Torppa How are you trying to change to the IP address? Through the DWC? Ideally, do it via YAT over USB, because you connect to DWC via an IP address! So if you change the IP address, you'll no longer connect.
                                  Realistically, you should connect via YAT, disable networking with M552 S0, then send M552 Pxxx.xxx.xxx.xxx S1, where xxx.xxx.xxx.xxx is the IP address you want to set. Alternatively, write this into the config.g in place of M552 P0.0.0.0 S1 that is there at the moment.
                                  As for the erase of the SD card, make sure it is fully inserted. If you have removed it, then reinserted it, while the Duet is on, it may not mount the SD card unless you send M21.
                                  Though if Windows is not recognising it, it's possible you removed it or powered down the Duet in the middle of a write, or the SD card itself is faulty, or has somehow got zapped, and has got corrupted. Usually the best resolution is to reformat it with the SD formatter utility, and put the files back on.
                                    A Former User @droftarts
                                    @droftarts
                                    Tried to do this, how ever routter does not regognize it after i try to fidle with the IP.
                                    This is so frustrating.
                                      @Torppa Then it may be down to your router. It's against 'best practice' to set the ip address static within the address range that the router normally provides DHCP addresses. I don't know that any router actively rejects a static address in it's DHCP range, but it might.
                                      A bit more information, like how you're actually trying to do this, or the copy the commands you are trying to use from the YAT, may help diagnose the issue. Get it working with DHCP again, send M552, then set the static IP address to the address that DHCP has given it.
                                        A Former User
                                        Cant get that far anymore, the sd card is again not regognized.
                                          A Former User
                                          intermittent connections issues could indicate IP conflict.
                                          could you run route printin your computer (it will tell us about he network in your computer).
                                          then M540 and M552on the Duet (in the serial/usb terminal)
                                          this should give us something to start working with to find out whats causing the issue.
                                            A Former User @A Former User
                                            hmm, include M20 and M122from the Duet's terminal please.
