RC6 crash with M409
this worked at least with RC3 or 4, did not test with 5, and 6 does not work ok
M409F"v,n,d10"
-> crash
M409F"v,n,d9"
-> crash
M409F"v,n,d3"
-> crashM409F"v,n,d2"
-> does not crash but does not return anything
M409F"v,n,d1"
-> worksIf I give it a key it works
M409 K"move" F"v,n,d4"
-> works
M409 K"move" F"v,n,d9"
-> worksmost times after crash it reboots, sometimes after crash it needs power cycle to get up
Which Duet?
Most Duets have insufficient memory to return the whole OM in one go, which is mostly what you are trying to do. But the firmware shouldn't crash, although you may get a network disconnect. Are you sure it crashed? What does M122 report for the software reset data?
iI you really do want to read the whole OM, the recommended approach is;
- Send M409 F"d1" to get the list of root keys.
- For each of those root keys, send M409 K"xxx" where xxx is the key. You can add F"v" to that command if you want the verbose keys too.
@dc42 said in RC6 crash with M409:
Which Duet?
duet2eth
ha, so new features... ok .. it worked on RC3/4 but yeah, more stuff added, all clear
Nope, not sure. Lost connection, then it returned, I assumed reboot, later on it just lot connection, did not return till power cycle. Will try now
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3SD6Q-KVRBF Used output buffers: 1 of 24 (24 max) === RTOS === Static ram: 28052 Dynamic ram: 93604 of which 20 recycled Exception stack ram used: 496 Never used ram: 8900 Tasks: NETWORK(ready,164) HEAT(blocked,1244) MAIN(running,1576) IDLE(ready,80) Owned mutexes: === Platform === Last reset 02:46:59 ago, cause: software Last software reset time unknown, reason: User, spinning module GCodes, available RAM 8892 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 4 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 7.1ms, max retries 0 MCU temperature: min 42.6, current 44.7, max 45.1 Supply voltage: min 23.9, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 0/350 Driver 1: standstill, SG min/max 0/356 Driver 2: standstill, SG min/max 0/1023 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-04-10 15:32:11 Cache data hit count 4294967295 Slowest loop: 15.72ms; fastest: 0.12ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 166, MaxWait: 439095ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 140, completed moves: 140, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is ready with "M122 " in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 39.51ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: no data received
I just wanted to dump the whole thing few times quckly and then diff the outputs to see what changed
.. not something I need to use normally in production
... it's totally ok as is, the lack of RAM did not came to mind
