    Duet 3 hc6 firmware '''issues''
    Firmware installation
    2.5k
      A Former User
      Sigh, I can understand the frustration; but unless the board was damaged the update shouldn't render it unrecoverable.
      And the update would only have affected one LED, the two indicating 5v and 3.3v are hardwired to the power rails - if they don't work something other than an failed update occured.
      If you find the will to keep at it; high resolution picture if the board would be helpfull in determining the cause.
        A Former User
        Got it to ''work'' again how ever Z and Y axis are reversed, the weird part is that DWC has no trouble homing only when manuly G1 Y34 F3000 Its the Z axis that mooves. The is something weird going on.
          A Former User
          I guess that implies it was never broken.
          Maybe its time to sit down and do some reading.
            droftarts administrators @A Former User
            @Torppa Post your config.g and home all.g.
            Check you have connected the Y and Z motors to the correct driver as per your M584 command, the physical order of the drivers on the board isn’t necessarily what you expect; it’s
            0 1 2
            5 4 3
            So driver 3 is behind driver 2, not behind driver 0.
            See the wiring diagram here: https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/TF1FBCbopEsxvYAv.huge
              A Former User
              on 3)
              ; generated by RepRapFirmware Configuration Tool v2.1.8 on Thu Apr 09 2020 16:09:20 GMT+0300 (Itä-Euroopan kesäaika)
              M550 P"My Printer" ; set printer name
              M551 P"***********" ; set password
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P0.1 S0 ; physical drive 0.1 goes backwards
              M569 P0.0 S0 ; physical drive 0.0 goes backwards
              M569 P0.2 S0 ; physical drive 0.2 goes backwards
              M569 P0.3 S0 ; physical drive 0.3 goes backwards
              M584 X0.1 Y0.0 Z0.2 E0.3 ; set drive mapping
              M92 X80.00 Y80.00 Z400.00 E409.00 ; set steps per mm
              M566 X600.00 Y600.00 Z12.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X15000.00 Y15000.00 Z180.00 E3600.00 ; set maximum speeds (mm/min)
              M201 X2800.00 Y2800.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
              M906 X2600 Y2600 Z2600 E1197 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X670 Y620 Z430 S0 ; set axis maxima
              M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
              M574 Y1 S1 P"io0.in" ; configure active-high endstop for low end on Y via pin io0.in
              M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
              M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
              M558 P9 C"io7.in" H5 F120 T2400 ; set Z probe type to bltouch and the dive height + speeds
              M308 S0 P"temp0" Y"thermistor" T97700 B4619 C9.743561e-8 ; configure sensor 0 as thermistor on pin temp0
              M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
              M143 H1 S285 ; set temperature limit for heater 1 to 285C
              M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
              M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
              M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
              M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
                A Former User
                The fans are cooling the steppers, aiming to print mostly nylon ans ASA, duet has a fan 240v for cooling. dont knoiw if this is abit mad for my first 3d printter
                  @Torppa said in Duet 3 hc6 firmware '''issues'':
                  So motor wires are connected like this?
                  Y0 X1 Z2
                   5  4 E3
                  I've just been playing around with the networking on a standalone Duet 3. This in my config.g works for me to set a static IP address:
                  M552 P192.168.0.28 S1                        ; enable network and set IP address
                  M553 P255.255.255.0                          ; set netmask
                  M554 P192.168.0.1                            ; set gateway
                  I can connect to the DWC, edit the IP address and reset, and the IP address will move to the new IP address.
                  I can also connect when starting up without an SD card inserted. Start up, connect via USB with Serial terminal (in this case Pronterface, as I'm on a Mac):
                  Connecting...
                  Printer is now online.
                  >>>M115
                  >SENDING:M115
                  >FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC4 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-03-16b1
                  >>>>M552
                  SENDING:M552
                  Ethernet is disabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0
                  >>>M553 P255.255.255.0
                  SENDING:M553 P255.255.255.0
                  >>>M554 P192.168.0.1
                  SENDING:M554 P192.168.0.1
                  >>>M553
                  SENDING:M553
                  Net mask: 255.255.255.0
                  >>>M554
                  SENDING:M554
                  Gateway: 192.168.0.1
                  SENDING:M552 P192.168.0.28 S1
                  Ethernet running, IP address = 192.168.0.28
                  >>>M552
                  SENDING:M552
                  Ethernet is enabled, configured IP address: 192.168.0.28, actual IP address: 192.168.0.28
                  >>>M552 S0
                  SENDING:M552 S0
                  Network stopped
                  >>>M552 P192.168.0.69 S1
                  SENDING:M552 P192.168.0.69 S1
                  Ethernet running, IP address = 192.168.0.69
                  >>>M552
                  SENDING:M552
                  Ethernet is enabled, configured IP address: 192.168.0.69, actual IP address: 192.168.0.69
                  I can ping all the addresses I set, even when running with no SD card. I did make sure to send the subnet mask and gateway before the static IP address and enabling the network, though. This is with firmware 3.01-RC4.
                  So I can't replicate the problem you are seeing.
                    With you motor currents set like this:
                    The Duet 3 should barely be getting warm, even without a fan. But then depends how close to other hot things it is, how confined the enclosure is, what the ambient temperature is. It's difficult to over-cool something!
                      A Former User
                      The enclosure is 350x350x50mm duet sits on 8mm pcb stands. has 3 went meshes, cables are running in the perimeters of the enclosure and the cable passtru holes have silicone thinggys that i salvaged from an old pc case.
                      Now that i think of it i might use the old itx case as the enclosure.
                      the PSU is not in the same box as the duet.
                      PSU, Mean Well RSP-500-24.
                        A Former User
                        MCU Temperature
                        29.7 C
                        Ambient is 24.8 C
                        Got the IP changed to a statick one last night, no idea how i did.
                          @Torppa you can calibrate the CPU temperature offset with https://duet3d.dozuki.com/Wiki/Gcode#Section_M912_Set_electronics_temperature_monitor_adjustment
                          • PrintMakeundefined
                            PrintMake
                            This post is deleted!
                              A Former User @PrintMake
